I 2nd that question
I have a cingular 8125 Pocketpc ...is there a software to connect me when someone calls?
M10000 mobo, low profile 512mb ram, 2.5" 120gb hdd, 80watt power supply
I'm assuming you mean is there a way to be connected via the CarPC?
If so, the only thing out right now is PhoneControl...but seeing as how the developer lives overseas, I've found that most of the phones I've had aren't supported.
StreetDeck is working on BT phone integration, but there's a lot of things left to be worked out before it will be offered.
Jan Bennett
there's a lite version for $120 that doesn't include nav...
I only threw it out there to tell you of the options that were avaliable or that are being worked on.
Jan Bennett
hya you should try the freefone program. it is free to download and is a really good program. see http://www.freedrive.co.uk/forums/at...5&d=1169071961 if this doesnt work then http://www.freedrive.co.uk/forums/showthread.php?t=635
lloyd
xXx
