good luck finding that, I doubt you will find that here though, or anywhere for that matter... check alpines website for there parts supplier, you may be able to buy a service manual for the 1004,,,
the 1004 has a low resolution screen though, think it's like qtr vga native & if your looking to do a pc interface you'll not be able to run it at native res anyway... once you have to scale it then you may as well just go in from a composite adaptor, either way the results will be fuzzy & blurry no matter what you do with that head, on small text & stuff especially, not so much with video though..
if you want to do a nice alpine hack then look into the iva d900... it has a 800X480 native screen... I tried to interface directly to that lcd but it's niether ttl or lvds & I abandoned it & went a different route.... if you hacked into that rgb of that head you might get some where, I wasn't looking for that though, I wanted to directly intercept the lcd & drive it directly...
also, the 901 has this "good" display as well as the f1 status pop out screen, the one with no tuners or anything built in.... forgot the # of that one.. tme-something..., the 900 is best to start with though as there now relatively cheap on ebay... $700 range usually give or take & depending![]()
LinkBack URL
About LinkBacks
