Results 21 to 30 of 36
Thread: using ipod touch to control relays
  1. #21
    May 2004
    UK
    Only just seen this thread - but what about:
    1) Commandlfusion iviewer for IPOD Touch
    2) PC and/or Global Cache with IR and relay outputs
    Why? - in this scenario, the Ipod Touch can control devices without a PC, and it can control the PC (think of remote interface) too.
    take a look here: http://www.youtube.com/watch?v=M--lNXpamDQ
  2. #22
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    that iviewer is perfect for the interface! thanks. the global cache on the other hand is $300... i think i'll pass on that though... but i can use some my original idea with the iviere (i think) tony g you helped me out again!
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  3. #23
    Dec 2004
    Los Angeles Ca
    just another option. dtmf decoder chip could work too. haven't figured out the details but it would work based on tones that you would get from a touch tone phone:
    http://www.youtube.com/watch?v=RmsoI...eature=related
    http://www.youtube.com/watch?v=kWQDNKzQRuA
    most promising examples using the DTMF MT8870 ic:
    http://www.foxdelta.com/products/repeater.htm
    and
    http://www.youtube.com/watch?v=3JgrGtE-oHs
    M10k
    My Car Pc Install
    My Boat Pc worklog
  4. #24
    Dec 2004
    Los Angeles Ca
    this was posted over at the arduino forums:
    http://blog.fonosfera.org/la-fonera-...mation-device/
    M10k
    My Car Pc Install
    My Boat Pc worklog
  5. #25
    Dec 2004
    Los Angeles Ca
    another update:
    looks as though ir frequencies used in remotes range between 38khz-50khz, so it should be inaudible.
    i just contacted simerec to see if i could hook up the audio out wire from the ipod doc connector straight to the vss pin. they are looking into it and will get back to me in a few days.
    M10k
    My Car Pc Install
    My Boat Pc worklog
  6. #26
    Dec 2004
    Los Angeles Ca
    bugbyte i probably need you to verify this works
    ok... even more research and i think i've come up with another solution. this is more expensive but more versatile:
    first start out with a hacked la fonera as a wireless bridge
    connect it to an then ethernet realy board
    then use the iphone's wifi remote control features to control the board
    M10k
    My Car Pc Install
    My Boat Pc worklog
  7. #27
    Jul 2006
    Brisbane, Australia
    Good to see you came up with a way forward. I'll be interested to see how it goes for you mate.
    RodW
    2007 Toyota Hilux with a CarPC..
    Worklog: http://www.mp3car.com/vbulletin/work...ota-hilux.html
    OziExplorer GPS Embedded in RR: http://www.mp3car.com/vbulletin/sb-s...iexplorer.html
  8. #28
    Mar 2009
    Hey scott, trying to send you pm but your box is full.
  9. #29
    Dec 2004
    Los Angeles Ca
    ah... sorry about that. if you click on my name i think you can send me an email...i'll try to clear out the pm box too... but email is best
    M10k
    My Car Pc Install
    My Boat Pc worklog
  10. #30
    Mar 2009
    sent you one on head -fi instead.
