Page 4 of 4 FirstFirst 1234
Results 31 to 36 of 36
Thread: using ipod touch to control relays
  1. #31
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    haven't given up on this..
    i just found insteom 8 zone sprinkler controler which is controllable via an wifi enable ipod touch without the need of a computer..
    ah crap... you need this too which brings up the price over 300 bucks
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
  2. #32
    Sheepdog rdholtz's Avatar
    Apr 2007
    Atlanta, GA, USA
    Quote Originally Posted by scott_fx View Post
    Looks to me like you might be better off with the SheevaPlug (spec sheet here) that Bugbyte is using, plus an Arduino board, all for less than half the money.
    You may note that X10's unit looks suspiciously similar the SheevaPlug. I'd hazard a guess that they're the same physical unit, but X10 has added home automation software to their version.
    If just enough is really good, then too much ought to be perfect.
    2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
  3. #33
    Jul 2008
    Forgive me if im repeating a post but i had a similar idea a while ago...i wanted to use the iphone to control a fusion brain (either via a pc or a written app for the phone (which would be preferable - if only i knew xcode)) this would not only be a very clean install but help the OSS community as well...just a thought
    Social Engineering will always win....there is no patch for the human ;-X
    ~~~~h@zy
  4. #34
    Apr 2009
    Blog Entries
    1
    I know its not cheap but this uses bluetooth to control many different things. It might work for your application.
    http://www.prautogy.com/
  5. #35
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Already been done
    Try this link:
    http://jalopnik.com/5493649/electron...yline=true&s=i
    I'm surprised it has not been discussed sooner. Try searching "RedEye" from ThinkFlood. RedEye is a hardware and software combo which communicates with iPods over wifi and relays the signals to whatever you want to control.
    Hope this helps.
    Mal
  6. #36
    Mar 2010
    Miami
    as much as i like the idea, you're using a high tech solution to an extremely low tech problem. most pumps are reversible and would require even more wiring when trying to operate them wirelessly. with switches, you would only need one switch per pump, i would prefer a switch which is momentary and latched. and then for the reversible function, you can have another switch control a relay to reverse the current to all of the pumps switches. all you would need is a place to mount these switches. this is the way that i would do it, however, when you find a cheap way to do this, i will be sure to try it out
