Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Post your custom iPhone docks!
  1. #11
    Jan 2009
    Blog Entries
    1
    The first one you posted is the same one I have. I don't think apple would ever dissable the phone from working with their cable.
  2. #12
    Sep 2008
    This isn't mine but I thought I would post it to wet your whistle. I need to create a dock somehow but its going to be tricky. Enjoy.
    http://hackaday.com/2007/07/03/make-...ods-ipod-dock/
  3. #13
    Low Bitrate fixinstuff's Avatar
    Jul 2005
    Illinios
    Wow this thread got way off track.
    Fixinstuff
    Been there, done that, replaced it with a smartphone.
    Scott AFB, IL
  4. #14
    Jul 2009
    Yeah I just flamed Apple for changing the dock connector in OS 3.0 (after reading I couldn't use the cheap cord off ebay). I'm just curious if you all have had any luck using the cheaper cords with iphone 3g 3.0 (jailbroken, but don't think it matters). I was mad enough when they changed the connector after the 3g, but the fact that they are now changing it with firmware is just a "WOW" - if in fact true.
  5. #15
    Sep 2008
    You cannot use a cheap a/v cable with 3.0 (jailbroken or not). No one has one out yet. You'll either have to wait for people to start making one based on 3.0 or buy apple's'.
  6. #16
    Jan 2009
    Blog Entries
    1
    Just an FYI, my cable is the apple cable.
  7. #17
    Jul 2009
    I've been reading that the audio portion still works, but not the video portion on the non Apple cables (iphone 3g 3.0 firmware). Is this correct? I'd like to buy a cheap cable and all I need is audio anyway. I realize I might get the "this is not supported message", but if the audio works after I say "ok", then I don't mind. Ahh Apple and their greed.
  8. #18
    Nov 2007
    I ordered MB129LL cable to connect headrests TVs, Car Audio and charger. It should work with OS 3.0.
    http://support.apple.com/kb/HT1454
    To reject unoficial/non-original/cheap/chineese cables apple has a trick to recognize the cable by measuring the resistance on pin 21. It is done by software wich desides what the device should do if particular cable is connected.
    http://pinouts.ru/PortableDevices/ipod_pinout.shtml
    Lexus RX300 CarPC progress:
    ██████████████████90%░
    Status:
    Got VOOMPC,
    RR,GPS, BT, WiFi, 5.1,ODBII
    Lilliput touchscreen.
    Almost done. Testing...
  9. #19
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by MasterODisaster View Post
    Yes, the audio output still works. I've found that actually the video output works but I've ONLY gotten it to work with videos in the iTunes library. The screensplitr app does not work. And yes, I have the official apple cable with the chip inside it.
    Want to:
  10. #20
    Nov 2007
    Quote Originally Posted by Bugbyte View Post
    Search for TVout app in Cydia. This app can set what other apps can stream to TV out cable.
    Status:
    Got VOOMPC,
  1. Replies: 7
    Last Post: 04-06-2009, 05:14 PM
