Results 1 to 3 of 3
Thread: Use my Iphone 3g as movie player
    Variable Bitrate seninha's Avatar
    Dec 2005
    Holland
    I wonder if anybody can help.
    Already have in my car a Active Iphone holder, which can charge the iphone but also allows me to attached everything to my carstereo,so i can listen to my music.
    Only thing that this holder does not have is a TV-out.
    And that is somthing I really would like to have in the car.That way the kids can watch a movie when we are on the road.
    Idea is to mod this active charger , and solder a tv-out cable so I can connect it to two 9" headrest LCD.
    Have already been trying to find out the pinout of the iphone connector, and it looks like I need to use pin 8:
    My question is:
    If I buy next cable, and took it appart and solder Yellow cable to pin 8 of my existing connector on the car holder/charger.
    Will TV-out be possible??
    Or will it not work at all??
    Gods right foot!!
    Renault Grand Espace 3.5 V6
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Buy the Apple cable. It includes a USB port and audio/video outs that will work for sure. There's a chip in the cable and TV output without the Apple cable is iffy.
    Want to:
    Jan 2008
    but-- if you are focused on doing this yourself, you will need to look at more pins.
    pins 1 + 8 are required for a composite video signal.
    pins 15 + 21 are "device connected" pins-- you need a certain size resistor across these to trigger the iphone to allow the tv-out.
    also, all of the apple connectors i have looked at on pre-made devices have never had all the pins. just the ones needed for the pre-made device to operate. so that means you would need to purchase a fully-pinned connector, and hack everything together yourself..
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
