I have a dell 600m hooked up to a carnetix, but the laptop won't turn on when i turn on my car. I can turn on the laptop by pressing the power button though after the carnetix is loaded even without the battery in.
I know the ignition isn't the problem since i am just using a 12v source as the ignition.
Any idea what's going on?
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
Ah, well in short you need to open the laptop solder wires onto the switch and bring them outside the case. There wires get connected to the startup-shutdown controller.
For more detailed you best get searching as there are loads of posts on this subject.
I can search on that, but it was to my understand that this wasn't needed for carnetix p1900?
That's what the green/whie wire is for.
I don't know where you got that little piece of information, but it is incorrect. The Carnetix has to simulate a press of the power button in order to initiate bootup.
If you don't feel like cracking open the laptop, I'd get a port replicator and hack that (or maybe the monitor stand to boot)
I have an inspiron 8600, which IIRC, uses the same dock/port stuff (double check). I paid I think around $45 for the port replicator (D/Port APR) and a monitor stand on ebay.
They are cheap and tons of them on ebay. I got the monitor stand for two reasons. One, two protect the laptop from crap rolling around my trunk, and two, it was so easy to remove the little power button board and short it out (on the inspiron 8600, this makes it boot when power is applied, you'd want to use the wires provided to pulse it, I used power management to shut it down when it loses "AC").
Here's a pic of the monitor stand and dock.
I don't mind opening up the laptop, i actually already have just have. I just don't know what to solder since my button has 4 pins.
Just keep poking at it with a screwdriver until it turns on, then you've found the correct 2 pins to wire to.
