Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: laptop or new hardware
    Jan 2007
    I'm in the final stages of my pc planning. I am going to start purchasing here in a couple weeks, but I've reached a fork in the road. I originally planned to go the mini-itx route for space and power reasons, but I've come across an old laptop with a broken screen. The laptop is my brother's (so i can get it for free ) is only a couple of years old. This is a link for the laptop. Now it is a 2.8ghz pentium 4, so I'm already worried about how much current this thing draws. I need to do some more searching on that, but I thought since it is a laptop, it has to be at least somewhat power efficient. But on the good side, it has a wireless card already built in which is a plus, and a new 100 gig harddrive.
    So if you had the choice between paying another ~$250 or so for memory, mb, processor, and hd, would you go with the laptop or not? part of me wants to start something from scratch, but part of me wants to go this route because of money .
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    You figuring in a power supply in that figure$$$?
    I went the laptop route myself both times around as the first one I had, and the second better one, I got virtually free.
    I'm happy with it. An Ampie or something would look more polished, but I get more oomf and I can take it out of the dock when I'm on the road.
    I ended up spending a bit more as I got 2 docks/2 monitor stands, etc so I can just bring it in the house to work on the software, but even with the auto-air adapter, that was probably ~ $110
    A good question would be, how hard will it be to have it automatically startup? Mine was easy by modifying the dock (and leaving the laptop usable on it's own), shutdown was easy utilizing ACPI and the built in battery.
    Jan 2007
    Well thats the problem I'm going to face with the laptop. I dont really know how I would power it. I don't want to use an inverter. I obviously need to research it a little more, but I really want some sort of shutdown controller on whatever power supply I use. I don't ever need to take it out of the car, so hacking it up completely wouldn't be a problem. I just dont know what to do!
    Apr 2005
    Boston, MA
    Quote Originally Posted by elimenohpee View Post
    Well, you could use a P1900, not an option I could use as due to Dell's proprietary power supply, it wouldn't charge the battery and to me that's a deal breaker.
    Auto-air adapters are pretty cheap. Shutdown is easy and can be done with power management. I have my auto-air adapter powered by a circuit that's only on with the key. In the ACPI setup, it's set to shut down X minutes when it's on battery, so when I turn off the car, the laptop runs on battery for a couple of minutes and shuts off. As far as starting it, there are various options depending on your laptop.
    What I did won't work for you, I jumped the button on the dock, not the laptop, the laptop won't "see" the button press on the dock until the external power (the auto-air) is applied. If I did it on the laptop itself, it would just stay running til the laptop battery died.
    You still need to power the screen, so you might want to look at the P1900, I believe it has a pulse output to connect to the power button.
    Jan 2007
    East Central FLA
    Like shotgunefx, I am using an auto/air DC-DC power supply on a laptop. FYI, it's a Dell laptop. My laptop had an internal modem, and using an idea from a fellow forum member (my apology - I don't remember who to credit), I wired the laptop's power button to the modem plug. Then I ran a regular phone line to a momentary switch on my dash. That way I can power up/down from the switch. Also, with the proper BIOS/Windows settings I go into/out of hibernation with just a quick push of the button, and if I forget, the laptop hibernates after 3 minutes via the power settings in Windows. I didn't go the dock route as my car doesn't have room for one (no trunk, no back seat, etc.), but the dock wiring would certainly be easier to hack than soldering direct to the laptop MB.
    Apr 2005
    Boston, MA
    Quote Originally Posted by lbridges View Post
    I originally wanted to use Wake On Ring, but my first laptop didn't have the modem, so I bought it and it didn't have the pads on the motherboard.
    Second one didn't support it in the BIOS.
    Jan 2007
    Wow, a lot of great information here. Thats a neat little idea about wiring the power button to the modem outlet. I guess like shotgun said, powering off wouldn't seem to be an issue if when the car is turned off, it would power off x-minutes on its own battery. But I really don't see the point of buying a dock if I'm never going to take it out of the car, ya know?
    Apr 2007
    Quick question for those with the Dell dock and auto/air adapter. If the dock uses the dell 90watt AC cord, would the 90 watt auto/air just replace it or should I go with the 130 watt. Dell offers both versions but only lists laptop model compatibility not docking port.
    thanks
    Apr 2005
    Boston, MA
    I hear you. The only possible reason I could see for the dock in your case would be to give you a second chance if you screw up soldering.
    Quote Originally Posted by OnTalyn View Post
    thanks
    The one I got was 90w, so far, it's been powering the laptop/dock without issue. Made by battery-biz (P/N#AA-5001), the seller on ebay (dsmiller_inc) doesn't seem to have the same brand anymore, but has several others (some of them 130W) though the prices are higher. So if it has whatever dell expects to see to identify the adapter as 90w or higher and provides 90w or higher than you should be ok. If in doubt, ask the seller. I did, (and the mfg just to confirm ), the way I phrased it was
    I want to run a dell dock and the laptop off of this. Dell requires a +90watt (equivalant to a PA-10 or PA-13) adapter for this (or the BIOS refuses to boot), they (mfg) said it was 90watts, again want to confirm that this will work for my application.
    I think using the appropriate Dell power supply number is most likely to get you the correct answer.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If I was to build one from scratch (without any part on shelf collecting dust), I will go with laptop + dock setup.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. Laptop shutting off when LCD connected via VGA
    By hari-bhari in forum Power Supplies
    Last Post: 03-12-2007, 12:40 PM
  3. Modded my laptop. Now it turned into a brick! HELP!!!
    By ephyouckay in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-30-2007, 08:38 PM
  4. If you are a laptop expert or technician, PLEASE read.
    By WoLLy in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 05-23-2006, 11:31 AM
