Results 1 to 10 of 13
Thread: Laptop use in car
    "Speaker of the Truth" veedubya's Avatar
    Nov 2001
    Laptop use in car
    I have been toying around with the idea of using a laptop in the car. Is there a way to have laptop plugged into 12V via cog. adaptor but to run off the laptop battery until the battery hit a certain % then kick over to the AC.
    Laptop plugged in battery at 100%-11% = running off laptop battery.
    Laptop plugged in battery reaches 10% = running off AC plugged in.
    I briefly searched for an Adv. Power Management Tool but found nothing
    thanks
    veedubya
    "Geeks dont need girlfriends we can ping ourselves"
    Sony Vaio 2Ghz 40G HHD, Routis 2004 GPS, 7" VGA TS Lilliput, BackUp Camera running RoadRunner with Simplistique Skin.
    Jun 2004
    why not simply use a DC-DC converter and have it plugged into the 12V cig?
    Nov 2001
    maybe the confusion was i referred to AC power in my last line.
    clearer scenario
    Laptop plugged in to cig. adaptor and battery at 100%-11% = runs off laptop battery while still plugged in
    Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adaptor
    Variable Bitrate Nerd2's Avatar
    Dec 2006
    Bristol/Cambridge, England
    Why would you want this?
    I would think it may be possible to do in VB..... possibly.....
    EDIT: Actually "AC" may be directly linked to battery, you'd have to have some sort of relay?
    Jan 2007
    East Central FLA
    It would help if the scenario for use was explained. For example, if all you wanted to do was have a way to sit in the car and run the laptop for an hour or so without draining the car's battery, then just insert a switch inline with the power cord to the cigarette lighter.
    Nov 2001
    Laptop plugged in to cig. adaptor and battery reaches 10% = runs off cig. adapter
    Not sure a better way to explain.
    If laptop battery is bewteen 100% - 11% it will run off the laptop battery
    If it drops below 10% then I would like it to run off the cig. adapter.
    As it is i have a 2nd battery that will be used for laptop and possibly 7" Lilliput.
    Just trying to think of a way to use laptop battery to a certian point before switching over to the 2nd car battery
    Dec 2006
    Errr, the question we have isn't 'what do you want to do?', it's 'why do you want to do it?'
    Nov 2001
    does my reason need to be more clearer than this
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    What's wrong with a manual switch? You switch it when the OS warns that your battery is low.
    Want to:
    Jun 2004
    Also, a laptop can run on a car battery for a looong time...
    I don't see any use of this...
  1. hooking up a laptop to car speakers?
    By djomlas in forum Newbie
    Last Post: 11-24-2006, 11:38 PM
  2. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
