Results 1 to 9 of 9
Thread: why carnetix or inverter for laptop????
    May 2007
    hi, i have a question about using carpc setup with a laptop.
    i see bunch of auto/air adapter that goes into cig jack and charges as well.
    why is there a need for carnetix or inverter when i can just use it with an auto air adapter? i mean, doesn't that charge while the car moves and hibernate while the car's off?
    trust me.. i've searched alot.. i still haven't really figured out WHY is it necessary to use those..
    help me out plz?
    btw. i'll be using a dell laptop (inspiron 6000)
    thanks in advance, guys.
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    inverter: people tend to choose this when they only have an AC adapter and don't want to spend lots of money.
    carnetix: the popular one outputs the 19V common for laptops (and, thus, same function as an auto/air adapter), but has additional features: SDC, and 12V for a 7" LCD.
    - If you won't use an external LCD, then you don't need the carnetix to power it.
    - If you already own the auto/air adapter, then you only need a 12v converter or just plug it directly into the cig socket if you're brave enough.
    - If you *don't* already own the auto/air adapter *and* will need a 12v converter for an LCD screen, then getting a carnetix just makes it easier because it's 19V, 12V, and SDC all together.
    May 2007
    ok..
    i have 2 cig socket in my 04 acura tl.
    can i plug lcd and laptop into each?
    and what exactly is 12v converter? (pic might help, sorry)
    thanks in advance
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by j2flo View Post
    I believe psyrex is referring to a 12v regulator
    Jun 2005
    Oakland, CA
    Quote Originally Posted by ComputerGeek View Post
    Well, not necessarily. (j2flo, this is tech stuff you don't need to know yet.) A regulator (linear or switching) generally refers to devices that deliver the voltage desired and dumps the rest. This might work in a car cuz the battery/alternator is at 13.8v, and a decent linear regulator will still be able to deliver 12v no problem (more headroom is nice, though). If you're doing 12v unregulated to 12v regulated, you'll need some sort of buck-boost topology, and that's usually referred to as a converter. Marketing-wise, sadly, the names are interchangeable.
    j2flo...
    cig sockets: well, of course you should be able to stick it into both sockets, but, um, don't you want to eventually hardwire everything to be a smoother install? I don't think of cig sockets as a limited factor in how many devices to install. By hardwiring, you also sidestep a potential problem of loose connections or low amperage stock wiring.
    12V DC-DC converters/regulators: try the ones in the mp3car store.
    May 2007
    thanks psyrex and computergeek.
    psyrex, i do have one more question. sorry, i have really been on this site searching and studying with references, however for certain questions, i'm not so sure yet.
    on the ebay, there is a dell auto/air adapter and it says 19.5v or something.
    my cig jack says 12v only. is that why i need a converter (or regulator)? i just want to go this route to be simple enough to do it myself without having to hire people to do it.
    psyrex, can you be kind one more time and show me the links to the converter or regulator that's 12v? or something i need to plug in my lcd and laptop into my cig jack without blowing anything?
    thanks in advance.
    sux i found out too late about carpc... sigh.
    Jun 2005
    Oakland, CA
    You don't need to hire anybody since it's not too hard if you give it some time to understand electricity. If you really just want to plug it into the cig socket, then just use the cig socket adaptor that comes with the LCD when you buy it (people tend to call this thing the "egg"; you'll understand why when you see it). It's not the best, but it works for your requirements. I still very much recommend you to do a proper install - not only will you get a good stable carpc setup, but you'll learn alot more about your car in the process.
    May 2007
    thanks, psyrex.
    i guess i'll study more to get the complete set up done.
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    Another consideration specific to Dell is if it has a "smart" power supply. Usually indicated by a barrel type plug with a thin pin in the middle.
    There's a chip in there that identifies the supply to the BIOS, if the BIOS doesn't recognize it, it will not charge the laptop battery. It may also post "F1 to continue" BIOS messages, disable the use of port replicators etc. Might want to google your model to see if they have it. My 8600 does. I found an adapter made by batterybiz that worked and powered the port replicator (~$50USD), Dell now makes one as well but I believe it's closer to $75-100usd, not sure if it's powerful enough for running a port replicator or docking station.
    If you have this type of supply, beware of auto-air adapters that are "Charge only"
    Might want to read this thread.
    Inspiron 8500 Power Question
  1. relay on a power inverter
    By gtz in forum Hardware Development
    Last Post: 08-16-2006, 06:54 PM
  2. Problems I've had with inverter (Sima 300w - 600w)
    By dagnasty in forum Power Supplies
    Last Post: 01-21-2006, 10:13 AM
  3. inverter startup prob~!
    By bulgogi777 in forum Power Supplies
    Last Post: 10-15-2005, 03:20 PM
  4. Setting up a swtich to turn off inverter when computer turns off
    By hd54321 in forum General Hardware Discussion
    Last Post: 11-29-2004, 03:36 PM
  5. odd inverter behavior
    By jshrieve in forum General Hardware Discussion
    Last Post: 04-10-2001, 05:53 AM
