Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Thread: Is PII(300mhz) dell laptop a feasbile starter carputer?
  1. #31
    Nov 2004
    St Louis
    Quote Originally Posted by qha_vn View Post
    i am installing RR on a pentium mmx 333MHz, 64MB RAM, 4.3GB HDD, win98SE, winamp 2.95 it works like a champ. OS start up time is less then 30 seconds, shutdown time is amazingly less then 4 secs.
    Careful with Win98. I think I switched to XP four or five years ago cause an RR function I wanted and some plugins wouldn't work in 98 or maybe it was .Net ..... something I wanted and eventually decided I couldn't live without.
    98 will work, but 2 things to keep in mind: 1) you're gonna haveta learn how to optimize your system manually and often; and 2) put CPU usage labels on your main.skin so you can monitor what mix of programs tax your system hardest.
    I ran that 500Mhz at 98% CPU usage with RR, Winamp 2.95, Freedrive .91, Cellular Modem, and taskbar. If I changed anything in the slightest, it would lockup. If I wanted to watch videos, I had to shut down RR, Freedrive and the internet connection. If I wanted to listen to internet radio, I had to shut down Freedrive. Notice a trend here.
    Jistari,
    You hit the nail on the head about the video. Lots of nav programs out there, but most are very graphics intensive. Add that to a frontend like RR which saves up to 8 pages of graphics and you quickly realize whats the limiting factor of your system. I do remember one of my installs had a Gforce 8400 video card in a VIA 10000 that was sweet.
    Sorry to say, though, you need to do the research for yourself. Ask the question in here about which is better and you're gonna get a different answer from every [HL]INDIVIDUAL [/HL], if you get my drift.
    Back to your question about battery drain, the definitive answer is - it depends.
    It depends on what startup/shutdown controller/motherboard combination you install and how you install it. I have a three way switch (ACC/OFF/Battery)prior to my DC-DC controller that I switch OFF when the car won't be used for a while.
  2. #32
    Variable Bitrate Jistari's Avatar
    Dec 2007
    New York
    Yup, I'm a novice, but I rather quickly surmised that whatever car pc I would end up buying did in fact exist somewhere in this world and it was in fact not draining my car from is box on the shelf . I just need to decide and get it a little closer to the car then I'll figure out where the switch goes to circumvent that draining problem.
    Ya, I just have to get "edjamacated" in the new language of these new (to me) chipsets and video options.
    Anyone have a link to a good site that explains the tech behind some of the more common solutions ?
    (i.e. a 500 Mhz celeron and a 500 Mhz P4 run at the same "speed" but they are not equal in performance. I guess you could reduce it to "what are the newer proscessors and motherboards" (assuming that they are more powerful at a given speed than their predecessors), but that hasnt always been the case.)
    PDP1170/TRS80/Atari800XL/Amiga500/286/486/P2/P4/C2D/i7 still a newb (but an old newb, been doing this a while) working my way up to "Complete Newb"
  1. My 2006 Scion xB (portable) Carputer setup! w/pics!
    By breaker021 in forum Show off your project
    Last Post: 01-05-2007, 10:34 AM
  2. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  3. laptop carputer - noobie needs help :)
    By bigdongers in forum Newbie
    Last Post: 11-22-2003, 09:19 PM
  4. Replies: 0
    Last Post: 05-18-2003, 11:59 PM
