Results 1 to 7 of 7
Thread: Pagine WarDriver (or any other experts)...
    Sep 2007
    Hey all,
    I'm using a Toshiba Portege R100 for my CarPC setup.. small, light, silent.... The laptop is in perfect working order, and I want to keep it that way.
    I'm in the process of using WarDriver's remote laptop power on switch, and should have that done tonight.. Sweet setup!
    My question is for the actual power to the laptop. I'm little bit of a noob here, but I have the ACC wire feeding my aftermarket stero headunit and my LCD Touchscreen display in my center console. I was thinking, since I have an extra AC adapter for my laptop (AC adapter is 75 watt, 15V and 5A), could I strip down the adapter plug wire that goes from my laptop to the AC converter box, and wire it to my ACC wire as well? That way, the laptop would get it's power when the vehicle is either started or in ACC mode, and with the WarDriver's remote power on swith, I can power on and shutdown the laptop as I need...
    I prefer not to use an inverter...
    Feel free to flame on my noobiness, but pertinent advice is also appreciated ! =)
    Cheers!
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    So you want to plug your laptop directly into the 12v your car uses?
    Your AC adapter apparently outputs 15v...your car outputs about 12-13v...therefore your laptop's battery will be doing all the work. (it will probably assume it isn't plugged in.)
    You either need to get an automotive (travel) adapter for your laptop...or use the inverter.
    Sep 2007
    Yeah, that's what I suspected...
    Although a car battery can provide between 12V-14V, I would be better off to ensure the proper power is sent to the laptop. I have 2 batteries for the laptop that can make the thing last for about 5.5 hours (idle-small load), but to charge whenever it's not in use and powered off, I bought this car charger thing instead of using an inverter...
    Input power is rated to 10-15V DC, and output power is rated to 15V up to 60W / 4A maximum. This should be fine... Now I only have to decide if I want to hack it up to connect it directly to the 12V ACC / CONTINUOUS feed from my center console, wire it directly behind my cigarette lighter switch or simply use the cigarette lighter plug attached to it...
    Any advice on that one ?
    Oct 2000
    DFW area
    Or install another cigarette lighter socket just for that auto adapter (that is what I did).
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Quote Originally Posted by DodgeCummins View Post
    Thats my vote too...plus if you ran your own you could use bigger wire that what is used behind most stock sockets.
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Sep 2007
    Thanks for the info guys...
    So no love for wiring that adapter directly to my stereo adapter wires (ACC, +12DC and ground) which feeds my headunit and LCD, huh?
    That's cool.. I'll check into installing a 2nd deathstick lighter socket. Do you guys know of any writeups to guide a noob ? If not, no worries...
    Apr 2006
    Central VA
    If you are looking to power it on with those other devices try using a relay.
    Otherwise for a simple install you can wire your "death stick" with the 12+ from the battery (use an inline fuse close to the battery) , grab a ground close to where you install it and put a switch in the dash to turn it off and on. All parts on on the shelf at autozone, advance auto parts, PepBoys, Wal-Mart ect...
    -WarDriver-
    Outdoor Nut
  1. Project Budget, Experts opinion needed...
    By Astromic in forum Newbie
    Last Post: 05-24-2007, 05:04 AM
  2. What do the experts think of this new psu
    By skydiver in forum Power Supplies
    Last Post: 04-25-2005, 03:59 PM
  3. To the experts
    By Speg in forum Power Supplies
    Last Post: 04-21-2005, 10:50 AM
  4. OBD-II Experts
    By pirate_king00 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 03-17-2005, 08:03 AM
  5. Some questions for Experts (Mercedes Install)
    By Longkesh in forum LCD/Display
    Last Post: 08-23-2004, 09:25 AM
