the carnetix will be the power supply, you can get another plug for your laptop, just the tip, radioshack like $4 or so, the original ac adaptor is not used in the install unless you choose to cut the plug off of that instead of buying a plug.
you will need to solder wires to your power switch to have the carnetix start & shutdown.
LinkBack URL
About LinkBacks
