for power look for a car adaptor for your laptop, you can use a conventional startup shutdown controller or webmasters laptop startup device if you still have a battery in your laptop. in some cases depending on the voltage your laptop runs on, you can use a carnetix power supply that also has a startup shutdown controller built in & it'll power it & control it too.
check out te sticky at the top of this laptop section for more info too![]()
LinkBack URL
About LinkBacks
. Ultimately, the system will only be the laptop, touchscreen, and any USB accesories that would be warranted (E.g. GPS,
