Results 1 to 7 of 7
Thread: Noobie with a laptop.
    Newbie FTWRUBI's Avatar
    Nov 2007
    Ft Worth, Texas
    I have a gateway m275 that I would like to use for a jeeputer. What modifications do I need to do to make this work. Or would it be better to do a purpose built jeeputer?
    Nov 2007
    Welcome LSJC member.. I thinking on getting a tablet PC to add to my jeep. Nothing too fancy just for entertainment and NAV.
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    Quote Originally Posted by FTWRUBI View Post
    Think about where to mount it, how to power it and how to control it.
    You are the only person that can say what is right for you.
    TruckinMP3
    Read the FAQ!
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    you don't need to do any modifications to make it work... it already works (you wouldn't be using it if it didn't )
    but seriously, you should start by reading How can I use a laptop as a carputer?, and Using a laptop as a carPC. the general FAQs should answer most other questions you might have.
    there is nothing special about a jeep vs. any other car with regards to a carputer, the equipment install and setup is the same for any car. the only difference will be the monitor installation in your dash. check out the worklogs and completed projects forums to see other jeep installs if you need ideas.
    good luck
    Nov 2007
    Ft Worth, Texas
    Thanks folks, dajeepman. so how did you know?
    Nov 2004
    St Louis
    Wow, a tablet in a Jeep.... biggest problem I can think of is off-roading. If you need GPS while off-road then you're gonna have to create a rigid mount, probably 3/32 stainless on three sides and latch the fourth. If not, GET ONE WITH A DOCK so you can easily remove it when the terrain gets rough or do like I did for my Mustang - build a rigid mount for the dock that somehow wedges the tablet in place and hope for the best. Tablets with docks are nice for multiple car installs and allow you to setup a test station at home.
    Nov 2007
    Ft Worth, Texas
    Well, I am going another route. I am looking at getting a purpose built unit due to the shock and vibration in the jeep.
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
