Results 1 to 10 of 17
Thread: Powering laptop
    Dec 2007
    Powering laptop
    How do you power a laptop to use it as a CarPC? Do you run wires from the battery back to the power adaptor of the laptop and power it that way? Or is there some other way?
    Elsewhere
    There are a few options, depending on the power requirements of your laptop.
    A car power adapter works well.
    There are regulators like the Carnetix P1900 that work well with many models of laptop (but not all!)
    An inverter will work, but isn't the ideal setup.
    How about the Wiki?
    Dec 2007
    By car power adapter you just mean a charger that plugs into the cigarette lighter?
    Elsewhere
    Yes.
    How about the Wiki?
    Newbie neilhart's Avatar
    Jan 2006
    Fremont, CA
    Lind power adapters
    I like the Lind DC to DC power adapters designed for autos. I use an automotive sytle relay latched by accessory power to cut fused 12Vs to the adapter. This then turns off the power to the DC to DC power adapter when you turn off the accessory power.
    The laptop will still be powered by its' internal battery (but won't drain the car battery).
    check out http://www.lindelectronics.com
    Neil
    neilhart
    aka Neil
    My Domain is www.sfba-corvette.com check it out!
    Dec 2007
    okay, say you use one of them, what turns the laptop off after you leave the car? wouldnt it drain your battery keeping the laptop charged?
    Elsewhere
    Quote Originally Posted by tacobandit View Post
    You can get a startup/shutdown controller for this purpose. You don't need one, but it makes life convenient.
    How about the Wiki?
    Oct 2004
    NY
    the best way to use a car adaptor with a laptop & no shut down controller is to simply wire the car adaptor to only have power with ign, then set the laptop to react with a shutdown or standby/ hybernate etc when on battery power for what ever length of time you choose. I've been meaning to write-up a comprehensive power guide for laptop installs for a while now, just haven't had the time
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    Quote Originally Posted by turbocad6 View Post
    That would be awsome! Can't wait!
    Dec 2005
    So what would be better: powering laptop through auto-adapter or using Carnetix PXXXX ?
  1. What could cause this problem? (laptop related)
    By Rocky388 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-17-2006, 04:17 PM
  2. Powering Laptop
    By fabiolover2002 in forum Power Supplies
    Last Post: 06-09-2005, 08:20 AM
  3. Powering laptop and 2 LCD's
    By berniejr in forum Power Supplies
    Last Post: 03-01-2004, 06:16 PM
  4. Powering up a laptop remotely
    By dmbrown73 in forum General Hardware Discussion
    Last Post: 03-07-2002, 01:25 PM
  5. Powering up a laptop remotely
    By dmbrown73 in forum Power Supplies
    Last Post: 03-07-2002, 08:40 AM
