Results 1 to 5 of 5
Thread: [Resolved] laptop with external touchscreen problem
    Dec 2005
    I have 3-4 years old HP laptop, which I connected to Lilliput. I have a small problem: if monitor is connected to VGA port, laptop will not go past BIOS screen (where it usually says Press F2 for Setup), and it doesn't matter if monitor is on or off. There is no problem with Hibernation and Stand-By, only when I reboot laptop. Did anyone else experience the same problem ? Should I try updating the BIOS ? Thanks
    Nov 2007
    Sydney, Oz
    Have you tried taking the laptop in the house and connecting it to a normal monitor as a test?
    Dec 2005
    first I have to find a monitor, because I have only laptops I already found new BIOS update, will try it tonight.
    Oct 2004
    NY
    wierd, I would try it with a keyboard plugged in just to try it, some pc's stop without a keyboard attached, maybe the bios is set up to look for a keyboard if an external monitor is atached? long shot, but first thing I thought of...
    Dec 2005
    It turned out, that problem was with USB connection for the external touchscreen monitor. I decide to dig through BIOS again and found option "USB Legacy devices support". It was enabled. Disabling it solved the problem .
  1. Touchscreen problem - Help please!
    By C4DAO in forum LCD/Display
    Last Post: 06-29-2007, 07:02 PM
  2. xp install to laptop hdd problem
    By thecrow in forum Newbie
    Last Post: 06-15-2005, 04:37 PM
  3. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 03:49 PM
  4. Need help with External USB Laptop HD
    By VWTronics in forum General Hardware Discussion
    Last Post: 05-26-2004, 01:58 PM
