Results 1 to 7 of 7
Thread: Gateway Laptop Remote Power Question
    May 2007
    I recently found out what happens to a laptop when a 4 year old throws it down the stairs ... fortunately it was only 5 stairs ... unfortunately the screen was destroyed. Since this happened i figured i might as well make the laptop my car pc instead of building one from scratch to save some money. i have everyuthing hooked up and it works fine with the screen in my car ... unfortunately i can not figure out how to remotely start it. The laptop model is a Gateway MX3414. I looked on here about making a remote button however when i opened up my laptop there would be no way possible for me to do what they said. I was wondering if anyone knew of a nother way to turn on a laptop remotely ... maybe through the modem or cat5 connection ... or possibly through the power supply.
    thanks in advance
    May 2007
    if there are any threads already stating this that i may have overlooked please post them
    Oct 2004
    NY
    search for wake on lan or wake on ring, but I would say that the best way is still to interface to the power switch itself... why can't you do that? can you see the power button inside the laptop?
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    Or for a simple solution, leave the computer on suspend and use a wireless mouse to wake it up.
    May 2007
    ehh i rather be able to turn it on and off through a switch
    May 2007
    here are 2 pictures of the switch
    Oct 2004
    NY
    ok, that is EZ...
    check this thread out, it has a pretty good discription of the process
    just take a thin wire & make a jumper & guess at a pair of terminals, if it works then you found your points, if it don't work try another, repeat till you hit the pair that will start it up, then follow that thread for making your connection
    good luck with it
    I think I'm going to try to sticky that thread in the laptop forum for now, till I get a more polished tutorial togeather at least
  1. Power help for new laptop CarPC
    By jwaters in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-06-2007, 01:15 PM
  2. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
  3. quick question re: laptop power
    By mkerr in forum Power Supplies
    Last Post: 10-21-2004, 11:37 PM
