Results 1 to 8 of 8
Thread: Power advice needed
    Jul 2007
    Power advice needed
    Ok so, I'm planning out my project and I know I'm going to use a Samsung Q1 ultra UMPC. Most likely running Streetdeck on it and already know I'll be using the SC-C1 sirius receiver and a GPS receiver. I was thinking of using an external sound device as well. I'd like to hook it all up to a USB hub. I'd like the hub so when I get out of the car, all I have to do is unplug the USB and the power cables and take the computer with me.
    The advice I need deals with how to power everything. My car has a built in inverter (dodge caliber) and a cigarette lighter. The inverter is under the center armrest out of the way and shuts off with the ignition. The lighter is slightly hidden as well.
    I've been stuggling to figure out first what needs external power and second how to supply power to the items that need it.
    I assume the hub will supply sufficient power to the GPS receiver and the sirius receiver and that they don't need any DC in to the unit itself. I'm hoping the Sirius to USB adapter won't need any power either but it seems like it does. I know some USB sound cards may need power but, it seems like some don't. I'll be using an FM transmitter to go right into the antenna of my stock radio so the simplest audio out is fine.
    If the sirius adapter needs power, that'll be three devices with only two sources. I'd rather not put a power splitter on the inverter but, it seems like that may be a viable option. I would assume it could handle the minimal amperage draw of the devices it'll be powering. That way, I could use the cigarette lighter to power the UMPC itself.
    I've been going round and round with this and I'd like to see what other people think. I'm probably making this much harder than it needs to be. Perhaps I've been obsessing too long. Anyone have any thoughts?
    Thanks in advance
    Jul 2007
    Here are the parts I was thinking of using
    UMPC:
    http://www.dynamism.com/q1u/main.shtml
    FM modulator to get audio to the stock radio:
    http://www.circuitcity.com/ssm/Audio...oductDetail.do
    Sirius adapter:
    http://www.rush2112.net/mkportal/mod...products_id=35
    Sirius receiver:
    http://www.crutchfield.com/S-fjzpfxp...aspx?I=607SCC1
    USB sound:
    http://www.newegg.com/Product/Produc...82E16829128002
    GPS antenna:
    http://store.mp3car.com/BU_353_Weath..._p/gps-002.htm
    For the USB hub, it doesn't really matter, there seem to be so many out there and they all seem the same
    Elsewhere
    FM modulators are garbage for sound quality.
    I wouldn't expect stellar sound quality from that USB sound device, but it could surprise you.
    For powering everything, I suggest reading some FAQs on the topic: http://www.mp3car.com/vbulletin/advfaq.php
    There are quite a few about powering a computer in the vehicle.
    As a general rule, inverters suck. Your OEM unit that's integrated in teh vehicle may be better than most, however. I'd still recommend going with a DC-DC PSU, though and save the inverter for when you need to plug in a blender or something.
    How about the Wiki?
    Constant Bitrate moboman's Avatar
    Sep 2007
    Cincy, OHIO
    22 bucks plus shipping for a cheap usb sound card!! Check ebay, I know there are chinese usb sound cards on there cheap!!!! I have even seen them with the FM Modulator built in.
    My Worklog
    I'm using my carputer 100%, but I still need to make it easier to use.
    Variable Bitrate billmee's Avatar
    May 2005
    USA
    First of all what do you know about the built in inverter.
    Is it a pure sine wave, what kind of power can it deliver?
    As for the USB devices I prefer to power them off of a hub with a seperate 5v source.
    Regulating the 12v from your Batt/Alt down to 5v is pretty easy to do for this.
    Jul 2007
    Quote Originally Posted by billmee View Post
    Well, caliber forums have it at 150W peak. I figure it should be able to handle up to about an amp constant. Thing is though there's no ground prong. Any thoughts?
    May 2005
    USA
    Quote Originally Posted by navmaxlp View Post
    You will have to make your own ground.
    Prefered spot it the same grounding point as the radio.
    _
    Mar 2004
    Little Elm, Texas
    I'd be weary....a cheap inverter will end up wreaking havoc on computer parts. If the voltage isn't regulated very well your parts will fail quicker than normal.
    Just a word of caution.
    Jan Bennett
  1. Audiophile advice needed!
    By 97GST in forum Car Audio
    Last Post: 06-12-2006, 07:09 AM
  2. Power Distribution Block recomendations needed...
    By 0okami in forum Power Supplies
    Last Post: 02-19-2006, 10:09 PM
  3. front end advice for a low power system
    By nealric in forum Software & Software Development
    Last Post: 12-31-2005, 09:49 AM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 12:13 PM
  5. HELP!!! Need advice - power problems...
    By mwinkler in forum General Hardware Discussion
    Last Post: 02-23-2001, 06:54 AM
