either will be fine.
I'm setting up a startup controller to my docking station. I will run 22 gauge wire to turn on the laptop via momentary switch. Does anyone know which momentary switch I should use? There's one that is 0.5 amps and the other which is 1.5 amps.
Thanks for the quick reply. I think I'll go with the 1.5 amp switch then since it's bigger and looks more sturdy.
it doesnt really matter. all you are doing is jumping two pins
At the very most it would use 200mA if that.
PROGRESS:
As a point of reference, I'm using a telephone extension wire to turn on mine. It's wired into the unused modem port. What gauge wire is that...around 28?
