Results 1 to 10 of 20
Thread: IBM R50 Docking Station Mod
    Feb 2008
    IBM R51 Port Replicator Mod
    Hi all! I thought I would let you all know what I'm up to with my car PC as this is my first install and I'm documenting every step as I go.
    Firstly, I decided on using a IBM R51 Laptop as it was lying around unused and had a port replicator with it. So I've set about designing my system around this.
    I saw that everyone else was soldering some wires and an external momentary switch onto the power button of their port reps so I thought I would do the same, but instead I installed a connector into the chassis of the port rep. This allows me to easily remove the port rep from the car and use it elsewhere if needed. I used an RCA socket as it was the best panel mount socket type I could find at the local store but it works really well, except I didnt line up the drill too well and its a little off center but it is insulated from the chassis, in case anyone is wondering (please excuse the blurry pics and the bad soldering job)
    Feb 2008
    BTW this Port Replicator can be used on any of the IBM A30, X30, T30-40 and R30-50 series laptops so I would imagine that you could use my pics as a guide for soldering the switch with other IBM port reps too.
    Jan 2008
    switch
    thanks for sharing your solution! I'm going to try this on my t42 port replicator.
    Feb 2005
    East Bay, Cali
    I did the exact same thing with mine r51 docking station. I just used a jack from RadioShack and a momentary switch on the dash.
    I also mounted my dock to a piece of wood and mounted the whole shebang in a plastic gun case that with the rear cut out. The case has foam in the top and holds the lappie safely in the dock and protects the carputer from things banging around in the trunk.
    Feb 2008
    Yeah I'm trying to figure out how I'm gonna mount the thing in my boot. Have you got any pics of your setup Thefdog?
    Jan 2008
    I just wanted to give a special thanks to assault for posting this mod with pics. After butchering my last port replicator, I decided to give it one more shot using a brand new port replicator. Thanks to the pics it now works like a champ.
    I looked at three different docking stations, the port replicator II, the mini dock, and the dock II. I believe that the port replicator II is the best one to use because of the wattage requirements. I'm using a car inverter to power my laptop so to be safe I used the port replicator II. If anyone has used the other port replicators with success, please give feedback.
    Feb 2005
    East Bay, Cali
    Other IBM docks
    I'll post some pics tomorrow of my install. It seems to work pretty well, just takes a little more space in the trunk than I'd like.
    I've also got the Think Pad Dock II. However, it takes standard 110V power cord input, as the power supply is built in, and I am not using an inverter in my setup. I wanted this one because it has an extra drive bay and a PCI card slot.
    I pulled out the internal power supply and began some trial and error to figure out what voltages go where, but eventually gave up. If anyone else has gotten this to work, please post, as I would love the added features of this dock.
    Cheers, Marc
    Jan 2008
    docking station
    I have one of the dock II as well. I thought it would be an easier install in the car, since it doesn't have that extra box to hide. But when I looked at the extra power draw, I decided to just stick with the basic port replicator II which seems to draw the least amount of wattage.
    The drawbacks are of course the ones you mentioned plus the port replicator II only has one usb port as opposed to four on the dock II. I had to use a usb port hub to connect all my peripherals.
    If you can get the dock II to work in your car let me know. My carputer sits underneath my passenger seat so when I test fitted the dock II it didn't fit as well as the port replicator II because the dock II is longer because of the extra dvd drive.
    I just got the port replicator II for my T41! I was thinking of mounting the replicator on a piece of wood in the trunk so it will stay in the car, and install/remove the laptop at the start and end of each day.
    How do you find the plastic clips on the replicator holding up to the bumps of the road? I would assume it wasn't meant to hold the laptop in place in turns and driving down less-than-perfect roads.
    Jan 2008
    ibm
    I leave my laptop in the car all the time, although I do wonder if it will be able to survive the harsh summer weather coming soon. Mine is setup under the passenger seat with the cables running under the center console.
    How well your laptop handles the bumps will depend on what kind of car you have. I have an evo with stock suspension, so bumps are a way of life for my car. They will get worse if I get coilovers unfortunately. Occasionally my screen will lose the signal from the laptop if I go over a big bump like railroad tracks. I'll usually have to undock and redock the laptop. Your T41 should have the hard drive shock sensor, whereby if it detects too much movement it will lock the hard drive for protection. Sometimes it works okay but on first bootup it would lock my road runner up while it is in the middle of playing a song so I ended up shutting it off.
  1. Docking station for ibm t30
    By alm4re in forum General Hardware Discussion
    Last Post: 07-17-2007, 06:56 PM
  2. Carnetix to IBM T40 docking station II
    By rinkk in forum Power Supplies
    Last Post: 06-25-2007, 03:27 PM
  3. IBM docking station and uSDC20D wiring
    By obrienj in forum Power Supplies
    Last Post: 04-02-2007, 12:11 PM
  4. IBM Thinkpad / Docking Station issues
    By ODYSSEY05 in forum General Hardware Discussion
    Last Post: 09-29-2005, 02:21 PM
  5. Laptop with docking station?
    By mpfjr in forum General Hardware Discussion
    Last Post: 08-24-2004, 05:29 PM
