well, you'll have to have remote control of a power switch somehow... if a docking station (with power button) is available for your laptop then you can hack into that instead of hacking into your laptop. (NOTE: only a real docking station will work, not a USB port replicator).
if a docking station (with power button) is not available for your laptop then you'll have to hack into the laptop itself. you can directly wire to the power button itself, or you can wire a jack to it, which will allow you to remove the remote power switch by simply unplugging it (I would strongly recommend this method over wiring it direct)
LinkBack URL
About LinkBacks
