Results 1 to 10 of 14
Thread: My Laptop install Theory
    Mar 2008
    Ok, So im about to do this, just waiting for my screen to come in.
    Basically i will run an inverter from an ignition powered source
    Turn the computer on, set the settings as follows:
    When lid closes no action
    Hibernate when batter reaches 90%
    With those two settings, coupled with teh touchscreen that would power on with ignition, the PC woudl remain running at all times. When the Screen turns on, tap it to take it out of hibernation. If for some reason that doesnt work, put a mouse somewhere and plug it into the USB hub mounted up front and move it.
    super duper simple, no long startup and shutdown waits, hibernate shoudl last at LEAST 2 days on a 90% battery.
    any commetns criticism?
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    I think you are confusing hibernation with standby. hibernation turns the computer totally off, it writes info to the hard disk so it will restore your last session. you can pull the plug, battery, or whatever and it will still restore the last session. touching the screen will not bring it out of hibernation or standby, best thing to do is extend your power switch.
    Mar 2008
    for soem reason, on my toshiba, when i click the mouse button only, it will bring it out of hibernation
    no keyboard keys etc etc
    Aug 2007
    Oregon
    I was talking about "tapping" your touchscreen lcd like you were saying.
    Edit: I can't with mine anyway, maybe for some reason laptops are different but I don't think so, search around if it's been done it will be here.
    Mar 2008
    liek i said, also if tapping doesnt work, a mouse mounted somewhere will work as well to tap the mouse button
    Aug 2007
    Oregon
    just giving you a suggestion for a more oem look/feel. everyone does it different and has their own preferences. guess I shouldn't of said this was the best way.
    Constant Bitrate slvrsol's Avatar
    Mar 2007
    When I tried this, tapping won't work once you shut off the the monitor. I just use a cordless mouse instead to wake it up from sleep.
    Mar 2008
    its going on this car
    OEM really isnt a conscern
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Love the car but what is going on with the camber on those rear wheels?
    "A rose by any other name is still a flower"
    Mar 2008
    its the only way to fit a 10j -30 wheel
    plus it has a Custom (designed by me) air suspensino, using 240sxc teyp suspensino alla round, instead of the stupid **** that came on it with the one piece front knuckle/shock thing.
    Its a VIP car, so honestly, the camber is normal
  1. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  2. Replies: 5
    Last Post: 06-20-2007, 04:19 PM
  3. Can't install xp on my laptop HD
    By camiloteram in forum Operating System Optimization
    Last Post: 07-12-2006, 03:34 PM
  4. Laptop Install Help!!!
    By Inspiron8500 in forum General Hardware Discussion
    Last Post: 07-02-2004, 11:21 AM
  5. Replies: 2
    Last Post: 04-26-2004, 07:29 AM
