Results 1 to 4 of 4
Thread: loopback adapter with relay
    Feb 2008
    I'm using a loopback adapter with a relay to power on my eeepc. The adapter works just fine. If the relay is already energized and I touch the two leads of the ethernet cable to the relay it turns on just fine. But if I connect the leads with the relay not powered then power it on it does not turn on the pc. My theory, is that the electronic pulse created when I energize the relay is somehow interfering with the function. Does this make sense? Maybe I can use a transister instead or a diode protected relay. Any ideas?
    Mar 2005
    loop back...
    What the hell are you talking about.. jk... ok how about a schematic?
    Feb 2008
    Well, I figured it out. Turns out my wake on lan function does not work when using battery power. So I cracked open the eeepc and soldered two wires onto the power switch.
    Mar 2005
    ahh
    ok i see where you where going now.. that was a good thought... I didn't see any mention about wake on lan, thats why i got a bit confused by the "loop back connector", anyway wake on lan looks for a special packet thats sent over the network, not a physical connection to the network.
  1. StreetDeck Functions
    By god_of_cpu in forum DigitalMods (Scripts / API)
    Last Post: 01-15-2008, 11:44 PM
  2. Will this work with an adapter?
    By Rublex in forum Newbie
    Last Post: 05-31-2006, 08:38 PM
  3. Lock-start-puter circuit.
    By KyleYankan in forum Hardware Development
    Last Post: 07-17-2005, 01:05 PM
  4. Alpine aux adapter issues
    By oekundar in forum Car Audio
    Last Post: 11-22-2004, 02:50 PM
  5. slim slot dvd rom with wrong adapter, questions
    By mattress in forum General Hardware Discussion
    Last Post: 10-24-2004, 09:51 PM
