Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Wiring Flow Diagram, please help fill in blanks
  1. #11
    Oct 2007
    Springfield, MO
    what extra wires would i have to run for a relay? You said there are two extra wires, my guess would be Acc and Ign? My main concern about a relay is where i'd put it.... Also with a relay when i turn my car off it sounds like the pc would turn off, unless i put an addition switch infront of the relay which would bypass the relay and direct signal directly to the pc.
  2. #12
    FLAC Nola111's Avatar
    Jan 2007
    New Orleans, LA
    You're going to want to run external power to the hub if you want to prevent potential issues, especially if you're going to have a slim DVD player hooked up to it. Also, in your diagram you're missing a data line (USB) from the touchscreen to the laptop.
  3. #13
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Nickwell24 View Post
    close ... one wire is a plain old ground (for the relay coil), the other is a switched power input (for the relay coil). the relay power input should be wired to the ACC or the IGN circuit. the ACC circuit (first key position) is live when the key is in the 'ACC' or 'run' position. the IGN circuit is live only when the key is in the 'run' position.
    a standard bosch-style relay has 4 or 5 leads. 86 is the coil power (from ACC or IGN line), 85 is coil ground, 30 is your PSU's power source (car battery), 87 is the switched output (87 and 30 are connected when the relay coil is powered). on 5-lead relays, 87a is the other side of the 'switch' (87a and 30 are connected when the coil is NOT powered. for your setup you have no need for 87a, so just leave it disconnected).
    I think I remember from one of your other posts that you wanted to use a lighted switch. if that is the case, then it would only be 1 extra wire (since you would be wiring a ground wire anyways )
    a 30A relay is generally a 1 inch cube... that's it. even with the wires connected it's still only about the size of a single "C" cell battery. you can pretty much hide it anywhere
    with a desktop-type setup that would be true. but since you're using a laptop, it can run off it's own battery. when the relay switches off, the laptop will simply stop receiving power from the car's battery. it would continue to operate with it's own battery until you turn it off (or it's battery dies). if you want to continue powering it from the car's battery without the engine running, then you simply leave the key in the 'ACC' position
  4. #14
    Oct 2007
    Springfield, MO
    What happened to the ComputerGeek Name?
  5. #15
    Newbie neilhart's Avatar
    Jan 2006
    Fremont, CA
    LCD Power
    I would suggest that you power your LCD Monitor from the 12VDC output of your power supply. The raw 12VDC from the car's system usually runs about 14.8 with spikes and sags on the line from starting and as other loads are switched on and off. The thought is that the regulated output of your PSU will give you generally better prefromance and life on one of the most expensive components in you system.
    Neil
    neilhart
    aka Neil
    My Domain is www.sfba-corvette.com check it out!
  6. #16
    Oct 2007
    Springfield, MO
    Because i'm using a laptop i'm not using a PSU, i'm running my power battery relay switch laptop power supply.
  7. #17
    Oct 2007
    Springfield, MO
    Fusion, question about a relay, if i have a relay before my switch when my car turns off is it going to kill all power to my switch? I'm guessing this is when the valet switch would come into play by by passing the acc line (relay) and sending power straight to the switch?
  8. #18
    May 2007
    Boston
    yes it will. if you wire a relay before your switch, then the relay will cut power to anything hooked up to lead 87. you shouldn't put a switch after the relay. remember, the relay itself is a switch, so there is no need to add another switch the the relayed power wire. if you add a switch, it should be on the coil power line (to prevent the relay from switching power 'on').
    no. the purpose of a 'valet' switch for a carputer is to manually cut power so that a valet driver (or anybody else you don't want screwing with your stuff) can't turn the equipment on. a 'valet' switch is wired on the coil power wire (lead 86). when the valet switch is in the 'open' position (off) then the relay coil will not be powered regardless of whether or not the car is on.
    a valet switch should be wired like this:
    you could wire an 'override' switch, but I don't really see the point. I can't imagine a scenario where you would need to use the carputer without the ignition key. if you want to use the carputer without the engine running, then just put the key into the 'ACC' position.
    IMO, an override switch would defeat the purpose of using a relay in the first place, so I wouldn't recommend it. that being said, if you still want to wire an override switch then you can wire it in like this:
  9. #19
    Oct 2007
    Springfield, MO
    Wow, thanks for the diagrams, it's really nice being able to see what people are actually talking about. Thanks man, the main reason for the switch is because it's about the only way the GF will be okay with me spending 2 - 3 weeks working on this and giving her no attention, because in her opinion the switch "looks cool", worst mistake ever is take a trip to radio shack w/ a girlfriend to buy a switch, they make you buy the "pretty one" so i end up w/ a $5 switch that looks like it belongs in an F-15 rather than a car.
  10. #20
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Nola111 View Post
    Nola can you explain this a bit more? I have 2 hubs that are powered with DC-DC adapters, but I was not sure how to connect them. I was worried that if I connected them to my relay, they would loose power before the PC could shut down or hibernate. So I decided to add them to the 12v rail on my OPUS 320. Was this a wise idea?
    HiJackX1 UAMCB w/ The Tobiathin Core Android/Win 7 hybrid system!
    4x 10inch Tablet
    1x Win 7 / Rear Entertainment PC
    ft/ Web Server Streaming
  1. Replies: 9
    Last Post: 08-02-2007, 04:02 PM
  2. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 06:19 PM
  3. Wiring diagram for Opel Corsa
    By wade in forum Car Audio
    Last Post: 10-10-2005, 03:56 AM
  4. My Wiring Diagram
    By mattdisaster in forum Power Supplies
    Last Post: 10-07-2005, 06:01 AM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 03:35 PM
