Results 21 to 30 of 36
Thread: Wiring Flow Diagram, please help fill in blanks
  1. #21
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Nickwell24 View Post
    the main reason for the switch is because it's about the only way the GF will be okay with me spending 2 - 3 weeks working on this and giving her no attention, because in her opinion the switch "looks cool", worst mistake ever is take a trip to radio shack w/ a girlfriend to buy a switch, they make you buy the "pretty one" so i end up w/ a $5 switch that looks like it belongs in an F-15 rather than a car.
    lol... that's funny.
    just tell her it's the wrong switch. or just use it for something else. (i.e. throw some mood lights on the ceiling )
  2. #22
    Oct 2007
    Springfield, MO
    the switch would actually work fine it's made for automobile installation, i'm considering using it for the screen and the Cigarette Lighters instead though, i hate the fact that cigarette lights are a constant drain on power.
  3. #23
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    It depends on the car though..... Mine shut off when the ignition is turned off.... The socket for the rear doesnt, and the one in the center console doesnt....
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  4. #24
    May 2007
    Boston
    Quote Originally Posted by HiJackZX1 View Post
    I have 2 hubs that are powered with DC-DC adapters, but I was not sure how to connect them. I was worried that if I connected them to my relay, they would loose power before the PC could shut down or hibernate. So I decided to add them to the 12v rail on my OPUS 320. Was this a wise idea?
    since you USB hubs run on 5VDC, you can power them directly from the OPUS +5V rail (instead of running two 12vdc-5vdc PSUs off the OPUS +12V rail). modern systems don't pull much from the +5V rail, so chances are you have enough unused power for your hub(s).
    yes, if you power the hubs from the main relay, power to the hubs will be cut before the PC shuts down. the solution to this is to run a second relay for the hubs, with the OPUS +12V rail as the coil power. (see diagram below);
  5. #25
    Oct 2007
    Springfield, MO
    totally random question, is it possible to use a DC DC adapter on a laptop install? or is there another way you can think to power a usb hub w/o using an inverter?
  6. #26
    Jul 2007
    Miami
    Quote Originally Posted by FusionFanatic View Post
    In the past i have connected USB hubs directly to the OPUS, which resulted in melting.... It may be because of polarity error or to many amps. Thats why I went with DC-DC adapters to kill my worries. I was also worried that the 5V rail would not be able to handle two 7-port USB hubs.... I would love to eleminate the DC-DC adapters though, they take up alot of needed space. What measures can I take to ensure nothing gets fried?
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  7. #27
    Jul 2007
    Miami
    I think, someone correct me, you can use the laptops power brick without an inverter. If you want to power the hubs, use a DC-DC adapter.... the ones I have only go between 4.5 and 6 volts. I have them set to 4.5 volts with no noticable issues.
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1x Win 7 PC
  8. #28
    Oct 2007
    Springfield, MO
    how would i use the brick w/o an inverter, it comes out of the brick on the laptop end as DC, but has to go in as AC.
  9. #29
    May 2007
    Boston
    the power brick that comes with a laptop is an AC-DC power supply. you would need an inverter to use it.
    you can buy DC-DC auto/air adapters. they look similar to the bricks that come with laptops, that may be what you were thinking of.
  10. #30
    Oct 2007
    Springfield, MO
    and that's another 100
  1. Replies: 9
    Last Post: 08-02-2007, 04:02 PM
  2. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 06:19 PM
  3. Wiring diagram for Opel Corsa
    By wade in forum Car Audio
    Last Post: 10-10-2005, 03:56 AM
  4. My Wiring Diagram
    By mattdisaster in forum Power Supplies
    Last Post: 10-07-2005, 06:01 AM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 03:35 PM
