Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Wiring Flow Diagram, please help fill in blanks
    Oct 2007
    Springfield, MO
    Jul 2006
    seattle
    what blanks?
    looks good to me.
    Oct 2007
    Springfield, MO
    anyone else? please i want multiple opinions.
    Elsewhere
    No mention of whether the USB hub is powered or not.
    How about the Wiki?
    Mar 2005
    humm
    Also your SWITCH. is it just that? just an on off switch?
    Feb 2005
    Cali
    Use a relay wired to the ignition
    If you use a relay with the ignition, you can ensure that you never forget to turn the switch off and come back to a flat battery.
    I've got a relay that controls a fuse box in the trunk wired directly to the battery (with a fuse as close to the battery as possible). From the fuse box, I power a Kensington 120W laptop adapter (which was spliced into to get a 5V line for my external soundcard), another 5V power adapter for my USB hub (from a 2W USB cigarette lighter power source), my amp for the front and rear speakers, and my subwoofer.
    Otherwise, it looks good
    Cheers, Marc
    Oct 2007
    Springfield, MO
    the usb hub will be powered through the usb line... not sure if that makes it powered or not.
    Oct 2007
    Springfield, MO
    The switch is just that, an on off because i only want this for longer than 5 minute trips... so i see no reason to install a relay and a valet switch when i can just use the switch.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    the point of the relay (as thefdog mentioned) is to ensure that power [to your pc, monitor, cig lighter, etc] is cut when car is off. you can still use a switch with a relay to only apply power when you want it. the relay simply ensures that you'll never have a dead battery because you forgot to switch power off to all your devices.
    your plain old on/off switch will work fine (as long as it can handle the current that all those devices will pull from it), but you'll have to remember to switch it off when you leave the car. otherwise it may drain your battery. with a relay you'll never have to worry about that.
    from this thread and several others you started (they are basically all about the same topic) you seem very reluctant to add a relay to your setup and I'm not really sure why. it will only make your life easier. they only cost $5 and it's only 2 extra wires
    Jun 2007
    As a low voltage electrician i agree totally. Use a relay. This way there is no OOPS factor. Will also help prolong the life of you battery from excessive deep discharges of you battery.......when you forget to turn off the switch.......that's my 2 cents.
  1. Replies: 9
    Last Post: 08-02-2007, 05:02 PM
  2. AutoPage 860 + 2000 Honda Civic Wiring diagram Help!
    By pcmofo in forum Hardware Development
    Last Post: 01-14-2007, 07:19 PM
  3. Wiring diagram for Opel Corsa
    By wade in forum Car Audio
    Last Post: 10-10-2005, 04:56 AM
  4. My Wiring Diagram
    By mattdisaster in forum Power Supplies
    Last Post: 10-07-2005, 07:01 AM
  5. datalux 4x20 red lcd wiring diagram?
    By etrik in forum LCD/Display
    Last Post: 12-07-2001, 04:35 PM
