Results 1 to 3 of 3
Thread: internal laptop question
    Dec 2007
    okay so would it be possible to use all of the components from a laptop and buy a new motherboard and use, say an m2-atx to power it all? Would it start right up if the mobo was compatible with the laptop components? Reason i ask is i am having troubles getting my laptop to power on, i had extended the pushbutton but it broke off so now i have to buy a new power/led board.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Most laptop componets will not work on an atx style board. Foe the most part, laptops use proprietary components and a different form factor.
    What components did you have in mind?
    You can use the cd/dvd drive and 2.5 inch HD with the right adapters.....
    Leonardo Da Vinci
    Dec 2007
    I was thinking about using everything except the mobo and get an new one, one that will run off of a power supply, so i dont have to worry about wiring up an external power button.
  1. Replies: 2
    Last Post: 07-11-2006, 06:11 AM
  2. Laptop set up question
    By portcity in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-01-2005, 08:47 PM
  3. display and laptop question
    By jstrain in forum General Hardware Discussion
    Last Post: 04-04-2000, 12:05 PM
