Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Which laptop?
    Oct 2007
    Springfield, MO
    Which laptop?
    Hey guys, i'm finally ready to start buying my parts but i need some advice first. What laptop are you guys using, i know everyone is using something different, i know a lot of people go with the IBM laptops, but i was hoping to buy something from stores like BB, CC, Office Max, something like that, does any one know what a good entry level laptop is that has a docking port on it, the websites never seem to say and i want to make sure i get a docking station w/ it.
    Oct 2004
    NY
    are you planing to r&i often & use out of the car frequently too? what kind of budget...
    Oct 2007
    Springfield, MO
    not sure what you mean by r&i, but no, the main purpose of this laptop will be the carpc. Eventually, years down the line i might have to use it for my proaudio programs when i'm EQing buildings and what not, but for the next 2 years at least it's primary purpose is in car, budget is approx 700
    Oct 2004
    NY
    r&i= remove & install, like taking it in & out on a regular basis.
    if that's not the case, a dock is less important. a dock will make connecting to the power switch easier, but only if the dock has a power switch on it, many don't. a dock may also give you a few extra usb ports, but again, there are other solutions for that too.
    there are so many different laptops out there, so saying which is best for this is hard. just about any laptop will work, you should be able to pick up something suitable just about anywhere, I'm not to sure why your really stressing the dock factor, I wouldn't consider that as much of a priority as you seem to be.
    I've had good experiences with dells & gateways as being easy to disassemble & reassemble to make connections to the switch for automatic starting & shutting down, but most dells are not dock-able, earlier IBM's are popular because they did have the power switch on many of there docks & docks are usually available cheap on ebay
    Fujitsu's are great machines & many have docks, but most don't have power switches on there docks... plus they can be a little pricey
    there are so many different laptops, as a general guide I think it is critical that you do make connection to the laptop switch, this would be one of the main criteria I would use in selecting a laptop to begin with. either search around for other successful connections to power switch to see what others are having good results with & you'll also see that some laptops are a nightmare to get at the power switch, again, here dells & gateways are usually very easy... if you see the power button is on the top of the keyboard area in a thin panel there usually easy, if you see a slide switch on the side to power it then that would be one of the very difficult ones
    another thing to mention is with dells, they are good machines for a carpc, they are easy to disassemble but they have a drawback of needing a proprietary power supply to charge the battery, where most other laptops just need a specific voltage to charge... what are you planning on using to power this & start it up & shut it down? if you permanent install it & power it with an atx supply you won't even need the battery at all in a config like that, & the power supply can also handle startup & shutdown...
    I see your looking to buy a new retail laptop for this, have you considered trying to buy a laptop on ebay with a busted screen maybe instead? for the same budget you should be able to get laptop, power supply(s), startup shutdown & still have some left over for other stuff...
    Oct 2007
    Springfield, MO
    I appreciate you taking the time to help, but i ended up pick an hp 14.1" that was on clearance at CC yesterday for only 450. Thanks though, now that i have this all I should be opening my worklog soon.
    Planned ... 95%
    Purchased 25%
    Installed ... 0%
    WorkLog
    Oct 2004
    NY
    cool, now you gotta figure out how to connect to the switch (HP's are usually easy too) & how your going to power & control it, what voltage does it run at? do you already have a solution for that, please don't say your going to use an inverter
    Oct 2007
    Springfield, MO
    Not sure about power, i want to keep the laptop as stock as possible. I've concidered using an AC/DC adapter that hp makes. the power reads 18.5 Vdc 3.5A, to control it i've already set up RR using Digital FX 3.0 which is awesome i must admit.
    Planned ... 95%
    Purchased 25%
    Installed ... 0%
    WorkLog
    Oct 2004
    NY
    how are you thinking to turn it on each time though?
    the hp car adaptor will be great to power it, you may also need 12v & 5v supply though for any periferals & usb devices & stuff..
    Oct 2007
    Springfield, MO
    Not sure about how i'm going to turn it on to be honest with you, that's one of the areas i haven't put a whole lot of thought to, I still need to read up on the forums for ideas on that one. I don't know a whole lot about car electrical wiring so i'm really tempted to get a local car audio store to run an extra 4 awg line w/ ground when i have them put in my subs. Eventually i'm going to have my laptop tie into an Alpine Ida x200.
    I think at this point the only USB items i will be using is a slim line DVD Player, a GPS unit (probably the BU-353), and the touchscreen.
    Planned ... 95%
    Purchased 25%
    Installed ... 0%
    WorkLog
    Oct 2004
    NY
    the best way to have a laptop behave like a carpc is to solder wires directly to the power switch. it is very intimidating but it is also pretty easy, & once you do that you'll never want to think about any other option. you can get a cheaper startup shutdown controller or even a cheaper small atx supply that will also give you 12v & 5v & also do the startup automaticly. even if you just wanted a push button on the dash you will need to go to this switch...
    you may also have to disable a lid switch, some laptops won't even start up when the lid is closed. if you want to put up any pictures I'd try to help guide you. if your really dead set against opening the laptop then I guess search & see what your other options are, but to me most times there are no other good options...
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 06:31 AM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 12:55 AM
