Results 1 to 6 of 6
Thread: Wake on lan
    Mar 2008
    East Coast UK
    Wake on lan
    Anyone used this to power up a laptop?
    If so How did you implement it?
    Low Bitrate Blaz3's Avatar
    May 2006
    Toronto
    This explains WOL in detail: http://gsd.di.uminho.pt/jpo/software...i-howto-2.html
    This pretty good tool i use for wake on LAN
    http://www.depicus.com/wake-on-lan/wake-on-lan-gui.aspx
    Blaz3 [|||||||||-] 88%
    Mar 2008
    East Coast UK
    Thanks,
    I know what WOL is I just wondered how you do it for a carpc?
    is there a switch you can buy for powering it up from the lan socket?
    Thats what I meant
    From the sticky:
    "one alternative to the power switch approach is a wake on ring or wake on lan type setup, but this only works on some boards & reliability can be a bit questionable, but if your dead set against opening the laptop this can be an area to explore."
    Mar 2008
    I couldnt find much info via search, was trying to implement wake on lan/link to my laptop, compaq v700 series..
    no option in bios, but options on network card
    found it only worked when supplied with ac power
    but made a switch, maybe 3 feet long, off of a DIY rj45 loopback device, wiring pins 1 and 3 together and 2 and 6.. put a momentary switch between 1 and 3, couldnt get it to work longer than 3 feet, low power i presume.
    looking for a momentary relay i guess itd be called..sense 12v power when i turn on key, complete that wire for a second and trigger laptop to fire.
    Mar 2005
    wake on lan is actual data sent over the network. These Magic Packet frames are directed to a specific MAC address and are sent by another computer to wake a remote computer. You cant just put a switch or something on the network cable.
    Mar 2008
    then I suppose my motherboard supports wake on link change or something of that sort
    as the loopback device (google.com:loopback rj45) works flawlessly with a momentary switch between 1+3
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 11:30 PM
  2. New take on wake on lan?
    By rniedzial in forum General Hardware Discussion
    Last Post: 08-29-2006, 03:16 PM
  3. Laptop powerup by wake on ring or wake on lan
    By ZeroDefects in forum Power Supplies
    Last Post: 08-25-2005, 11:01 AM
  4. Will 802.11n support Wake On Lan?
    By Danceheaven in forum Wireless Communications
    Last Post: 03-01-2005, 12:19 AM
  5. Wake Up Lan
    By CorollaVerso'04 in forum General Hardware Discussion
    Last Post: 06-21-2004, 09:43 AM
