Results 1 to 7 of 7
Thread: Power Button Question...
    Apr 2008
    Hello, I am new here, but have been lurking for a while. I am in process of doing a remote power button on my laptop but seem to have run into a point of confusion, now I am not doing the soldering myself but need to inform the person I am having do it exactly what needs to be done, can somebody please explain to me the best way to achieve this... Thank you! I really appreciate any help!
    2002 Nissan Maxima
    Stillen Lip Kit, S-Tech Lowering Springs, 19" TSW Nogaro Rims, Greddy Exhaust, Lots more :)
    Car PC: P4 2.8 w/ HT, 1gig DDR333, 250GB 5400rpm HD, 7" Lilliput Eby701, Holux GPS Reciever.
    Status: Installing.
    Mar 2006
    Colorado, but Canadian!
    The 2 pins you have with arrows, if they really do turn on the PC when bridged, then solder 1 wire to each of those points. Those are now your button leads into your DC-DC and/or manual button.
    1.9in x 2.9in -- 47mm x 73mm
    Apr 2008
    I am just curious if it is even possible to solder something like that, there is very little to no solder holding the power button on.
    2002 Nissan Maxima
    Status: Installing.
    Jan 2007
    Charlotte, NC
    It's possible ... but you need a steady hand and a magnifying glass.
    I just did the same thing on an Asus P548L (Something like that) MB ...
    It really is a simple switch ... one side of the switch is 5V+ and the MB waits for that 5V to get pulled to ground before initalizing.
    All you really have to do is figure out which leg of the switch is 5V and solder your wire there. The ground side of the switch can be soldered to any part of the chassis that is grounded.
    I ended up soldering my connections on the bottom side of the MB ... not the gap in between the switch and the MB ... it was too tight in there (1 mm I believe ...)
    perk03z06
    Windows XP PC
    InTruckPC
    P4 3.0 GHz Hyperthread CPU, 1Gb RAM, 120 Gb Hard Drive, DVD/CD-RW, Centrafuse XLE 1.47, 7" Xenarc, GPS, EV-DO via Samsung i730 ... more coming!
    Oct 2004
    NY
    check this sticky thread out to get an idea of how to solder to that switch
    Jan 2007
    Charlotte, NC
    ~OR~
    Check this thread:
    http://www.carnetix.com/forum/showth...=2920#post2920
    Talks about USB ACPI ... no soldering the MB needed!
    perk03z06
    Windows XP PC
    InTruckPC
    Dec 2007
    I have tried multiple times to solder 2 wires to the points and no matter how careful i am it breaks everytime. Its so much of a PITA that i bought a barebones system and am putting my laptop HD into it just to be done with my system.
  1. Xenarc MDT-X7000 PC power question
    By PJinBolton in forum LCD/Display
    Last Post: 02-01-2008, 08:51 AM
  2. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  3. Noob question about power supplies
    By Jagojon3 in forum Newbie
    Last Post: 03-09-2005, 12:35 AM
  4. Power Supplies Specs Question
    By rushnrockt in forum Power Supplies
    Last Post: 02-19-2005, 02:34 AM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
