Results 1 to 10 of 13
Thread: Power Button problem
    Feb 2008
    I have a gateway 7508gx laptop. I looked at the power button and im not going to beable to hack it. I want to be able to just use a cigg adapter to power it but I cant figure away to turn the laptop on without lifting the lid and hitting power button. I dont see any wake on anything in the bios either.
    Other options?
    Feb 2008
    I really dont want to go with a dock either. Just wondering if anyone has thought of something else then what I have seen in the FAQs
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by americanskiff View Post
    why not?
    Feb 2008
    Would rather just go with laptop no dock if possible
    May 2007
    Boston
    did you read the quote above the "why not?"
    ...I was asking why you think your laptop's power button cannot be "hacked"
    Feb 2008
    Ohhh....Well, I wont be able to hack it. The circuit board below the power button is a very small strip and where the power button is it is very very very small. With a eye I cant even tell where the contacts are for it.
    Feb 2008
    I called and asked a few electronics places if they could do it and they warned right off that if something broke or melted they would not be responsible if it did not work again. Doesnt sound good to me
    May 2007
    Boston
    all laptop power buttons are tiny. if you can't see the 'contacts' on the switch then it may have leads that go through the circuit board, soldered on the other side. if that's the case then it would be easier to solder than other laptops (which use surface mount switches).
    Jun 2005
    chicago, Illinois
    Plus, the power button is uses low current, not enough to melt anything.
    PROGRESS:
    Jun 2008
    Where are you located? If you are near Maine, I would be willing to solder the wires to the switch for you.
    Rick
  1. DSATX problem, not power switch problem!
    By VThokieME in forum Power Supplies
    Last Post: 05-04-2008, 01:22 AM
  2. Power button won't work when laptop lid is closed
    By scotty562 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-22-2006, 11:25 PM
  3. problem with power opus power supply in the car
    By customaudioman in forum Power Supplies
    Last Post: 08-21-2006, 06:09 AM
  4. M2 ATX Power on problem
    By JWise1203 in forum Power Supplies
    Last Post: 07-26-2006, 12:24 PM
  5. wierd power problem (opus or m10000 prob)
    By ob1 in forum Power Supplies
    Last Post: 03-31-2004, 02:32 PM
