Personally I think you went the wrong route. The
carnetix would have been your best bet. For a few reasons.
(1) They run about 90-95% efficient
(2) There not too much money
(3) There stable
(4) They handle huge voltage fluctuations up to 30 volts dc for input
(5) Auto switching, which means if you car spikes above its normal operating voltage (which happens quite often) it will be able to recognize those changes and adjust as needed. I can testify to this with my car, it had a failing voltage regulator and would jump from 13.5 volts up to 18 volts pretty quickly and the carnetix took it like a champ.
(6) The
p2140 also offers the secondary output. Your screen should allways connected to a regulated
power source. I would not trust your car to do this. Most of the screens being sold can not handle power flucuations or power above 14 volts. Yes your car will get above that. I assume this is what most of the screen failures reported on this site are from. I learned this after a few years ago when I lost two screens in one year. I monitored my voltage on the car and compared to what the screen is supposed to handle according to the manufacturer. Lilliputs only handle up to 13volts according to there website. Your car will get above that gauranteed.
I used to run an HP e-pc with a
series of
relays and a
tank circuit. It worked well but there was no real shutdown sequence. The computer would get the signal to shutdown then it would only cut off the power to the computer once the 12v rail on the pc was discharged. Needless to say if the computer hung, my tank battery would die. Of course it was kept seperate from the car battery, but after killing and recharging the tank all the time that battery had to be replaced every few months.
I guess all I can say is, speaking from experience if you cut corners on your install just to save money you will end up not as satisfied and will eventually end up doing what you were trying to avoid in the first place. Spending a little extra money for the higher quality components.
JUST MY 2 pennies
