Results 1 to 10 of 19
Thread: How to default to external monitor?
    Jul 2006
    When I pull my laptop out of standby upon turning the car on, it doesnt display to the external monitor about half the time. I have to cycle it in and out of standby a couple of times to get it to show up on the external display. I have checked the connections and everything seems to be intact, and the display is on before the laptop comes out of standby. How can I make sure it it defaults to the external each time? It's a PITA to reach in the back and manually switch....
    Mar 2005
    I was about to post the same thing, I have a HP laptop and you have to keep pushing fn + F4 to output to the VGA port, can this be set any way by default otherwise you miss stuff like the boot screen/resume screens on the VGA port.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    There is a option within Windows to change the Identity of the screens with in Windows. Right click on desktop, go to properties, then settings tab, then under advanced somewhere. Cant tell you exactly because my processor hasnt come yet. My ATI embeded graphics had this issue, doing that seems to have fixed it.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Just shooting from the hip but...can you set it in the bios?
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Oct 2007
    I had a similar issue with my Fujitsu. Once in a while it wouldn't switch to external monitor when booting even though it was configured as primary on the BIOS.
    My Fujitsu uses an Intel graphics chip. You can configure the intel software to switch between internal and external monitor by pressing a key combination, in my case I use Alt-F1.
    I wrote a small vb script the uses the sendkey command to send the key combination that switches to external monitor. I have it set to run on start up and as a scheduled task that runs every 3 minutes. So far its been working perfectly and theres no flickering or anything during normal use.
    Code:
    Option Explicit
    Dim WSHShell
    Set WSHShell = WScript.CreateObject("WScript.Shell")
    WSHShell.SendKeys "^%{F1}"
    WScript.Quit
    May 2008
    I have same problem with Dell laptop running winXP home, and I have try every tip found here and still can get the the touch screen to turn on after came out the stand by or sleep mode. any tip?
    Oct 2007
    Quote Originally Posted by stephenzheng View Post
    At a minimum, using your graphics card management software you should be able to define a hot-key to switch monitors. If you can do it from the keyboard then it should work from the above script. All this is assuming you have setup your TouchScreen to Auto-ON when power (or maybe signal) is restored.
    May 2008
    Quote Originally Posted by silvi4000 View Post
    I'm knowing very little about computer, and have no idea how to do that can you show me step by step how is done? thank you very much!Stephen
    PS, I don't have the mian monitor anymore, am have no problem with the usb touch screen if I boost the PC with the power botton.
    Oct 2007
    From the top then,
    you say it doesn't automatically switch to the external monitor. When this happens what exact steps do you take to make it work?
    How do you make your computer use the external monitor once windows is running?
    May 2008
    it only happen when the computer went to standby after X amount of time I set when I turn the car off (running the laptop battery) when I start the car I can hear the laptop running (the HD and the fans) but the 7" LCD not turnning on doesn't matter how long I waited. when that happen I have to hold the power botton for like 5sc to turn it off then back on (re-boost)thanks.
    the lid is off the laptop and I have a magnet on the sensor to make it think the lid is closed.
  1. Lilliput 619 Touchscreen Monitor
    By TeamRSX in forum LCD/Display
    Last Post: 06-23-2008, 11:22 AM
  2. 2002 Toyota Tacoma Monitor Issues
    By sprkyjtm in forum Fabrication
    Last Post: 06-15-2008, 10:50 PM
  3. Replies: 10
    Last Post: 08-20-2006, 04:57 PM
  4. How to use an external monitor with the laptop closed
    By hylyx in forum General Hardware Discussion
    Last Post: 06-12-2005, 02:13 AM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
