Results 1 to 7 of 7
Thread: Removing screen from inspiron m600
    Feb 2006
    Ontario Canada
    Hey, I have an m600 with a non working screen.. The vga output still works so I would like to connect it to another screen, but want the laptops LCD Screen off completely.
    Any ways, while removing the screen I cut the the cable which connects screen/lid to laptop base and the vga no longer works.
    This is the cut cable
    http://cgi.ebay.com/DELL-D500-D600-6...24111006r14582
    So how would I go about running the laptop off the separate vga connector, but removing the lcd completely and have it all work.
    Thanks.
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    my guess is that you have a short from cutting the wires - I'd remove the keyboard and palm rest then take the LCD VGA connector off the mother board.
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Constant Bitrate scatebase's Avatar
    Oct 2008
    Feb 2006
    Ontario Canada
    tried that.. did not work.
    Feb 2006
    Ontario Canada
    never mind it did,
    Apr 2006
    Central VA
    Glad it works.
    -WarDriver-
    Outdoor Nut
    Low Bitrate FockMasterDan's Avatar
    May 2008
    Westerville, Ohio
    When you removed the screen did you notice if there was an antenna in the lid? I know lots of laptops have it there, but not sure if Dell did it on these models. I have an 8600, but it's the same design (mom has a 600m - looks identical).
    Computer is in the car, but in a very "raw" install right now.
    Worklog - here
  1. 2007 Mazda 3 Dash Screen looks OEM
    By Splash-X in forum Show off your project
    Last Post: 05-04-2009, 05:29 PM
  2. Replies: 34
    Last Post: 11-06-2007, 02:42 PM
  3. My screen goes black when audio is playing.
    By HiJackZX1 in forum General Hardware Discussion
    Last Post: 10-22-2007, 06:56 PM
  4. 7" Dynamix (LinITX) LCD - white screen problem
    By xraycat in forum LCD/Display
    Last Post: 10-22-2007, 12:43 PM
  5. Removing test screen
    By quicky1980 in forum LCD/Display
    Last Post: 09-20-2006, 11:27 AM
