Results 1 to 9 of 9
Thread: I need help with my Laptop diagram (re-upload the pic)
    Newbie ado0o's Avatar
    Jan 2009
    Heeeeeeeeeeey Guys
    am kinda New with the Car-Pc thing
    So ... am starting my own Project
    and am gonna use an old Laptop
    with a 10.4' touch screen
    also am gonna add an auto reverse cam ( still dont know if its Usb or AV )
    and i have no idea how am i gonna do it hhhhhh
    I Just Draw the Car pc Diagram ...
    tell me if it missing something
    (re-upload the pic)
    and any idea will be thankfull
    FLAC WuNgUn's Avatar
    Sep 2007
    Is your cam USB?
    What frontend will you be using?
    Jan 2009
    am gonna put an auto reverse cam
    and the frontend ...
    mmmmm maybe RR
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by ado0o View Post
    there are no fuses in your diagram
    Jan 2009
    the regulator is having a bulit in fuse
    should i put an external fuse
    if so .... tell me where to put them ??
    Thnx Dude !!
    Sep 2007
    You should put a fuse at the main battery junction, and probably another one at your regulator and another for the touch screen....
    May 2007
    Boston
    that fuse only protects the regulator itself
    should i put an external fuse?
    yes, an in-line fuse is required within a few inches of the power source. this is to protect the power wire from staring a fire due to a short circuit or drawing too much current. the fuse cannot exceed the ampacity for whatever wire gauge you use. this site has some good info on wire guage, ampacity, and fuse ratings.
    you must put a fuse at the beginning of any power wire, and anytime you reduce wire gauge or split into two or more smaller wires (unless the smaller gauge wire can handle the current that the main power fuse is rated for).
    remember, its always ok to downsize a fuse, but NEVER go higher than the wire can handle.
    Constant Bitrate WarDriver's Avatar
    Apr 2006
    Central VA
    Does the screen you are using have a feature that automatically switches the video input to the composite input when voltage is applied? If so you are missing the auto part of your automatic reverse camera diagram. Generally you can pull 12v+ off of the reverse lights to accomplish this....but only if you want it to switch over every time you put it in reverse. You could also throw in a toggle between the reverse lights and the screen to disable that feature.
    -WarDriver-
    Server Administrator
    Outdoor Nut
    My DC to AC Inverter Mod
    My Laptop Remote Switch
    Jan 2009
    Quote Originally Posted by WarDriver View Post
    Does the screen you are using have a feature that automatically switches the video input to the composite input when voltage is applied? .
    yeah it is
    Planing ..................... 100%
    Important Parts ......... 100%
    Accessories Parts ......... 80%
    Working ..................... 100%
    Done!
    My Project ( Lot Of Pics )
  1. HOW TO:use opus with a laptop......
    By turbocad6 in forum Power Supplies
    Last Post: 06-25-2009, 07:31 AM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
