Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Start laptop when AC Power
  1. #11
    Low Bitrate Flaring_Afro's Avatar
    Sep 2008
    VA
    when its in hibernate, windows isnt running. its the equivalent of being off, just it saves the ram to the hard drive. if software wakes it up, your computer isnt going into hibernate.
  2. #12
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    will this work to wake the laptop from standby...??
    thats the onlything missng from putting my msi wind in the car... i need a way to start it up, and cant get wake on lan to work
  3. #13
    Apr 2009
    It's called your finger.... Just kidding. Do you mean you're mounting it in a location that isn't within your reach?
    I couldn't get my Aspire to wake on lan either. If I wanted to I could build the momentary power switch, but for right now I'll stick to pushing the power button and letting software turn it off.
    Has anyone gotten the OPs method to work in any form or fashion (hibernate [which I really suspect wouldn't work like others] or standby)?
  4. #14
    Jan 2009
    Quote Originally Posted by marazi View Post
    I too am running an MSI wind. I have it in my glove box and its just annoying to reach in there and turn it on everytime i get in my car. What i did was tell it to allow the touchscreen to wake it up from standby. So whenever i get in my car i just tap the screen and windows pops right up and im good to go. Now the only problem i get is that the battery doesnt last very long in standby. Not 100% sure why not or how to get it to last longer but its really annoying me now!
  5. #15
    Apr 2009
    Quote Originally Posted by dragons0088 View Post
    You are keeping in mind that anything connected to your USB ports are sucking up power right? If you have a long enough drive to recharge the batteries think about the 9 cell. http://gizmodo.com/5208885/msi-wind-...t-and-day-long
  6. #16
    Jul 2008
    work in vista
    thats work for in vista but the scheduled tasks wake up from hibernation every 1 minute even when i dont dont get ac power.
    i check the box "Stop if computer switches to battery" but the computer still make it and then go to hibernation mode (i don't plugged ac power).
    what i need to check at the "if the task runing"?
  7. #17
    Apr 2009
    Quote Originally Posted by Flaring_Afro View Post
    This is 100% correct and this is exactly why this process will not work in hibernation. The only difference between "shut down" and "hibernate" is the fact that windows saves the current programs running, etc to disk, then shuts down just as it would if you clicked "turn off computer"
  8. #18
    hxe
    hxe is offline
    Sep 2009
    I have solved this problem by activating wake-on-link feature on my laptop (Compaq Mini) network adapter and using mini ethernet switch which is powered when I'm turning my car on.
    Laptop will go to the hibernate mode after 10 minutes when it's running on battery.
    Buffalo USB mini ethernet switch is really small and can take power from USB port. I have 12V universal laptop car adaptor with USB port and the ethernet switch is connected to it.
    This solution works both on stand-by and hibernate.
  1. Hardware Review: M3-ATX Power Suply
    By Bimmerstyle in forum The Review Palace
    Last Post: 03-05-2008, 06:57 PM
  2. How can I use a laptop as a carpc?
    By turbocad6 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-11-2007, 01:55 AM
  3. Giving ITX and 300w ATX setups, capabilities of a laptop?
    By Vineet Singh in forum General Hardware Discussion
    Last Post: 10-15-2006, 02:12 PM
Tags for this Thread
