Results 1 to 10 of 18
Thread: looking for alternative to W3bmasters auto power on module.
    Apr 2008
    Hey guys, im looking for w3bmasters auto power on module but it seems that he's not making them anymore. can anyone recommend any alternatives please? thanks in advance
    Elsewhere
    If you want to permanently install the laptop in the car, how about a Carnetix.
    Someone wired up a plug for the motherboard power lead into the side of the laptop. That would work, as well and looks clean as hell.
    If you want portability or a Carnetix won't work w/ your laptop, how about rigging up a means of providing a WoL or WoR signal through the appropriate port?
    How about the Wiki?
    Apr 2008
    ive tried the WoL and it doesnt seem to work reliably on this particular laptop, but even so i would still need to press a button wouldnt i? i havent heard of WoR, any information on that particualr subject would be appreciated. As for the carnetix, i thought that was primarily for full size motherboards such as the P4? i just ordered the laptop car charger to power it and i have a switch soldered to the button controller of the laptop so i can push a button at the front of the car to turn it on and im using shutcontrol to turn it off. im at a loss for other ideas other than w3bmasters module, but ive been waiting for about 2 months now for him to become available again and it doesnt seem like its going to happen. thanks in advance!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You need a time delay relay. When power is applied, it closes the relay for 2 seconds, then opens it. This site has a diagram of one and the second comment down is by a user who added a capacitor to make the circuit close for 10 seconds. Adjusting the cap would shorten the delay, I'm sure.
    Want to:
    Apr 2008
    i purchased a 12V SPDT 30 AMP AUTOMOTIVE RELAY on the advice of someone for this site, they told me that with this relay when power is applied to the circuit the switch will be triggered and turn the laptop on. now my concern is that power is applied when when i turn the key twice, once when it goes to acc then during the crank the power turns off then on again. is this going to hit the switch twice if i simply use the relay? i dont know too much about relays so its all new to me. and if this is the case, will the schematic you pointed me to take care of that particular problem? thanks in advance
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Probably. If you can figure out how to make it wait a few seconds, it will work.
    The schematic I pointed you to should avoid that problem but read it closely. You want it to wait a few seconds before closing the relay, then close it for a short period of time, then release.
    Want to:
    Mar 2009
    Lightbulb
    I find this:
    http://www.xobyte.com/
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    well i got the circuit diagram for w3bmasters module... if you can solder you should be able to make them by hand in 15 min
    Apr 2008
    that would be SUPER appreciated. do you have the one with the usb cable that tells it not to send a signal when the computers already on? thanks in advance.
    Oct 2008
    Odense, Denmark
    yep
    it's on his own page
    Code:
    http://w3bma5t3r.com/modules/coppermine/albums/userpics/10002/module_schematic_1-6-2007.jpg
  1. Replies: 19
    Last Post: 10-04-2008, 12:11 AM
  2. What Power Supply for Laptop Install?
    By D3LTR33 in forum Newbie
    Last Post: 08-04-2008, 07:41 AM
  3. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
