Results 1 to 8 of 8
Thread: remove screen and connect vga display
    Maximum Bitrate boelle's Avatar
    Oct 2008
    Odense, Denmark
    i have a medion md 98300 that i want to use for carpc
    but can i remove the screen and connect a indash screen instead? and how is that done?
    Variable Bitrate hailrazer's Avatar
    Mar 2008
    Columbus, Georgia
    Quote Originally Posted by boelle View Post
    You remove the factory screen , unhook the lvds cable and the inverter cable. Put the laptop in the car where you want it. Run the external vga cable from the laptop to the dash mounted Vga screen and push whatever button combination on the laptop to activate the external vga monitor. Usually function and f4
    Constant Bitrate sergatiuk's Avatar
    Mar 2006
    also if you want your lappy to always recognize the VGA as the primary monitor, after removing the factory screen and attaching the vga disconnect all power, remove the battery, remove the little round battery on the mobo, wait a few mins, reconnect everything back, VGA should be primary screen now (;
    Oct 2008
    Odense, Denmark
    what i want is remove the factory screen and connect an external vga to the lvds socket so that i can have a dual screen setup
    EDIT: Maybe this one does the trick? http://www.orbitmicro.com/global/lvd...0-p-10904.html
    EDIT: my connector at mainboard:
    EDIT: closeup at panel connector
    whole panel
    wires at the motherboard connector
    wires at the inverterboard
    wires at the panel connector
    Oct 2008
    Odense, Denmark
    in the part of the display cable that goes to the panel there are 4 twisted pairs and 5 single wires along with a screen
    can any help out how i ident each wire?
    Oct 2008
    Odense, Denmark
    solved this one.. the ones who make the panel was so kind to give me the full spec sheet.. so now i can both make that lvds interface to an vga interface and make that panel an vga monitor
    Newbie Slimline's Avatar
    Nov 2004
    Arlington, TX
    Can you provide the diagram? Take a screen print and upload the picture to Photobucket or something?
    Oct 2008
    Odense, Denmark
    there are no diagram, each laptop has it's own pinout on the panel
    but i use the LVDS-VGA-R10 from tri-m systems and the pinout for that module are as follows:
    you have to get the pinout for your panel and then match up each pin of this module
  1. Use Ipaq Touch Screen Display As Carcomputer Lcd
    By sullivan2002 in forum LCD/Display
    Last Post: 01-08-2007, 02:31 PM
  2. Replies: 6
    Last Post: 11-08-2006, 06:57 PM
  3. Xenarc 700TSV 7'' touch screen
    By krazymarine in forum Classified Archive
    Last Post: 09-20-2006, 11:55 PM
  4. in-dash DVD HU with touch screen and VGA???
    By DaveB in forum LCD/Display
    Last Post: 01-21-2006, 04:43 PM
  5. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
