Results 1 to 2 of 2
Thread: Starter switch laptop power on
    Newbie fixit31's Avatar
    Nov 2009
    This is a diagram of a relay to show you a simple way to power on your laptop when car is cranked.
    You will need to find your wire from the ignition switch that go's to the starter. When you crank
    your car the starter has a momentary switch that will send power to the relay only when cranking.
    Put hot on pin 86. put a ground on pin 85. wires from laptop power switch on pins 30 . 87. If you use this
    you will need to setup in windows to do nothing when power button is pressed.
    To turn off laptop i use ShutControl found here on mp3car. you probably can find color code for the starter wire with a google search for your make and model car.
    TRY THIS AT YOUR OWN RISK I TAKE NO RESPONSIBILITY. This is the setup i use works good for me Name:  starter switch power on.jpg
    Nov 2009
    It saves pushing a button.
  1. 2007 Ford Fusion Carputer (version 2.0)
    By FusionFanatic in forum Show off your project
    Last Post: 04-20-2009, 05:56 PM
  2. My laptop power on solution - 56k modem port and telephone cable
    By sivart321 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 01-25-2009, 09:43 AM
  3. wiring a power switch to laptop
    By tacobandit in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-11-2008, 06:57 AM
  4. Question about Laptop Power on/off
    By ashiq32 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-01-2007, 09:11 PM
  5. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
