Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: What kind of Momentary Switch?
  1. #21
    Dec 2009
    Why don't you sell your laptop, and get a small voltage one like a EEEPC or something. That's what I've got. It pulls 9.5V off it's car charger. My lighter adapter wire is only on with the ignition. I am using ShutControl to hibernate the PC when it loses A/C connection after running SyncToy to sync my media drive if my home PC is near by. It stays charged at 100% unless I sync up like 100Gb or something crazy.
  2. #22
    Sep 2009
    I got the laptop I have for free with a cracked monitor. So I figured I would make use of it.
  3. #23
    Newbie warrenj38's Avatar
    Mar 2007
    Alberta
    I just inherited a travelmate 7520 with a smashed LCD. The screen is long gone but the body works great so its going in my car. I am facing similar power issues and have come to the conclusion that I will set up a switched connection (acc), wire up the DC to DC brick that I am buying to it, and run my laptop body as such. When the laptop senses power loss at the "brick", it will timeout in say 10 minutes and go to hibernate. Only thing to do is rig a power switch to the laptop body itself for remote start, or use a USB power solution and problem solved, yes?
    If you only knew the power of the dark side.....
  4. #24
    Variable Bitrate Wayne613's Avatar
    Apr 2009
    Delaware
    Quote Originally Posted by warrenj38 View Post
    I'm unsure as to what you're planning here. So you're getting a DC-DC power supply that can output 19v, and you wish to hook this up to the laptop minus the LCD screen, is that it?
    Assuming the above to be true, you would need to tap the 2 contacts going to the power button on the laptop and [with the correct polarity] connect those in parallel with the PS's motherboard on/off line. Of course putting that in parallel with I assume a new momentary switch mounted elsewhere. This will let the DC-DC PS send the remote on/off signal automatically, and give you manual control when the PS is on as well.
    2008 Ford Mustang GT/CS CARPC(99%)
    Software: Ride/Road-Runner, Digital FX skin 5.x, iGuidance 2011, GPSgate on Win7 64bit
  5. #25
    Dec 2008
    i think it would be easier to just set the laptop to shut down after 5 min of being on the battery power, and have it auto-wakeup upon ac power. if you can do that (depends of bios), then all you need to do is put a switch inline with the power going into the laptop... and also that way, when you hit the power button you cut all juice going to the laptop so your car battery is saved.
  1. Replies: 28
    Last Post: 06-12-2009, 09:41 AM
  2. Need wiring help for 2005 Grand Prix.
    By derekmac in forum Car Audio
    Last Post: 09-21-2007, 09:42 PM
  3. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 10:58 AM
  4. Control switch
    By warnockm in forum Power Supplies
    Last Post: 03-14-2005, 12:26 AM
  5. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
