a momentary switch is a switch that will only make contact when you push it. a standard switch will stay in whatever position you put it in-- which could be bad for a power button.
i think you should only need a single pole single throw (SPST) switch-- that makes contact when pressed. though a double pole single throw(DPST) switch will work, you will just leave the N.C.(Normally Closed) contact not connected.
LinkBack URL
About LinkBacks
