Results 1 to 10 of 12
Thread: Boot your carputer by remote?
    Apr 2010
    Lightbulb Boot your carputer by remote?
    Hi.
    I've been looking for a thing like a remote that i could use to turn on my laptop, it can be asleep, i heard that could be a problem too...
    If you have any ideas just tell me please, oh btw, I can't mess around much with the circuits but I can spend up to $200.
    I hope you can help me
    Constant Bitrate almera's Avatar
    Aug 2004
    Elsewhere
    If you have an alarm in your ride that has aux outputs, you can use the keyfob to trigger a relay to initiate startup of the PC.
    How about the Wiki?
    Maximum Bitrate bratnetwork's Avatar
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by DarquePervert View Post
    This is what I do. On top of that I have my Fusion Brain sense that that line is hot and it will run a script to make sure my wifi is enabled so I can remote into it or transfer files from my desktop.
    Variable Bitrate we87's Avatar
    Nov 2005
    Dallas, TX
    How would you go about doing that?
    Would you wire into the power button on the actual motherboard?
    The only reason I ask is because this sounds like a great idea, but I know the M2-ATX will not turn on unless the IGN wire is hot. So my mind says you'd have to make a circuit that emulates itself as the IGN. But that sounds alot more complicated then it should be.
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Everything is in the car and working.
    I painted the cilpboard mount and it looks good.
    Shutdown/Startup is working excellent!
    View My Progress Here
    Elsewhere
    we87 - A relay can and will do just that.
    It acts as a switch of a constant 12v line.
    How about the Wiki?
    Nov 2005
    Dallas, TX
    Well, You'd have to build a timer circuit with some caps that would keep the relay open for however long. Because an alarm AUX output just "pulses" and doesnt stay "latched" at all.... At least not on mine.
    Carputer Progress
    [||||||||||] 100%
    Finally Installed!!
    Oct 2007
    Haledon, NJ
    Quote Originally Posted by we87 View Post
    That all depends on you alarm. I have a viper system and i can set any aux to be momentary, stay on as long as the button is held, or latched (stays on till button is pressed again), or latched with IGN rest (stays on till button is pressed again or if the ignition is turned on then off).
    Jul 2010
    that's an awesome idea, so you have it set so that the aux is your power supply to the pc?
    Constant Bitrate funkyphil's Avatar
    Sep 2007
    CHI-TOWN
    Hey Bratnetwork,
    I have a viper alarm as well, mine is the 5901. Do you know if this alarm will give me the same feature to latched until i press the aux again? And if so, will I still needed the relay to make this work?
  1. REMOTE Carputer + Amp
    By mrborrie in forum Power Supplies
    Last Post: 07-18-2008, 12:35 PM
  2. Project: DIY Dual Remote - 2 remotes in 1!
    By WarriorRocker in forum Input Devices
    Last Post: 04-03-2008, 11:15 AM
  3. recommend a remote control for carputer
    By fallnangel in forum Input Devices
    Last Post: 01-16-2005, 09:51 PM
  4. My Weekend of carputer hell!
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 01-05-2005, 09:19 AM
  5. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 11:52 PM
Tags for this Thread
