Results 1 to 9 of 9
Thread: Can't get windows installed onto the SSD?
    Aug 2005
    Ireland
    Help please.
    I can't get windows installed onto the SSD on an Acer Aspire One AOA110-AB from my usb stick. The windows installation on it previously messed up, I reinstalled on an NTFS partitiion only to discover it was unsuitable so I wiped it clean again.
    It won't format properly either from the windows USB stick but I have got hiren's boot cd on usb so i can use all the facilities on there. They don't seem to be working either even though I can format correctly to FAT32.
    Setup has determined that Drive c: is corrupted and cannot be repaired
    Press f3 to restart etc etc
    That's the error I get when it's inspecting the drives right at the start of the installation. I can't get past it.
    What can I try next?
    Any help would be great.
    Baz
    May 2009
    i know this is few days late but you haven't mentioned the windows version in question.
    Aug 2005
    Ireland
    It's ok I got it fixed.
    It was windows xp pro.
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Please describe what you did to correct the problem. That way when others search in the future and find this thread they don't just get "got it fixed" but an actual solution. Thanks.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Aug 2005
    Ireland
    I made a bootable USB stick with an N lited version of windows on it. I streamlined the chipset, VGA, sound, and network drivers on it. The normal version of windows didn't work for some reason.
    Before I loaded it up I made sure I had the official Bios drivers Version 3309 from the acer website installed also via USB stick.
    That's about it really.
    Newbie flyINsky's Avatar
    Apr 2011
    I am having the same issue - I was going to install Windows 7 OS on here and ditch my Vista. Windows 7 won't recognize my Corsair 128 GB SSD drive. I boot into Vista and I can see it, format, assign a drive letter and read/write from it.
    Boot off the Windows 7 DVD, it sees my other drives but not this one. There are no drivers for this, so what do I do from here? I guess I could install Vista clean on the SSD and upgrade to W7 - but I'd rather get a clean tight W7 install if I could...
    I would LOVE some ideas here, as I would love to be able to install W7 on this SSD and watch it scream!!!
    Nov 2010
    Quote Originally Posted by flyINsky View Post
    I had a similar issue with a vertex 2 drive, the solution ended up being installing the latest firmware onto the drive. Have you tried that?
    Apr 2011
    I'M sorry.
    Nov 2010
    I'M sorry.
    You're sorry for reviving a thread? Did you get your issue fixed?
  1. Install Windows XP on a USB Flash Drive
    By kingofl337 in forum WinNT Based
    Last Post: 01-11-2012, 12:26 PM
  2. Road Runner on Windows 7 beta
    By DaveDog in forum Road Runner
    Last Post: 12-18-2009, 12:02 PM
  3. Windows Vista
    By thanatos106 in forum Software & Software Development
    Last Post: 06-28-2006, 10:56 AM
