Results 1 to 3 of 3
Thread: Archos umpc
    Sep 2008
    Archos umpc
    I’ve been thinking about my current carpc build recently. It’s dangerous to think too much as things change.
    What I originally wanted was a computer that I could use indoors, check emails, surf the ‘net and then plug into my car and use it as a carpc. My original idea was the OQO V2 but unfortunately it appears the company has gone under. The idea meant as I was walking to the car I could start up the front end, get into the car, plug in display, external HDD and a usb device or two. Listen to my music or radio on the way to work. Unplug pc and take into work allowing me to use pc during breaks etc. OK, the OQO screen was a tad small but the idea was set. With the advent of the iPad, tech companies have been bringing out Android umpc and my ideas are beginning again. So I found this ARCHOS 9 which runs windows7 and is a fully functioning pc running an atom chip (Z515).
    Is this capable of running a frontend, external HDD (for music), OBDII and maybe GPS or a recording video camera? Thoughts, concerns…
    Elsewhere
    Yes, it is capable of all that.
    The problem is the hassle of taking it in and out of the car. There are several things to connect/disconnect. If you can get a dock for that Archos unit, that will make the process far easier.
    Also, the Archos doesn't have a touchscreen. I don't know if that is an issue for you or not.
    How about the Wiki?
    Sep 2008
    Quote Originally Posted by DarquePervert View Post
    That's good to know. The 9 does have a touchscreen.
    DISPLAY 8.9” LED backlight
    1024x600 pixels
    Resistive touch screen
    but I will have an in-dash touchscreen anyway. Also the 9 has a dock - includes 2 x USB and VGA port. Just wondered if the CPU had enough 'grunt'.
  1. Archos 5 IMT Install
    By upspace in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 08-21-2010, 12:40 PM
  2. The UMPC dies. And no one notices.
    By CarlB in forum General MP3Car Discussion
    Last Post: 05-10-2007, 04:16 PM
  3. Asus R2H UMPC
    By htsource in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 04-09-2007, 02:45 PM
  4. Replies: 8
    Last Post: 01-22-2007, 06:57 PM
  5. Streetdeck on v7110 UMPC?
    By rniedzial in forum StreetDeck
    Last Post: 09-11-2006, 08:41 PM
