Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 47
Thread: Android Tablet as carpc
  1. #11
    Jul 2008
    Quote Originally Posted by tripzero View Post
    That's exactly what I'm talking about. If the cig lighter doesn't turn off (like mine doesn't), how long can he run before killing his battery? It's not going to automatically shut off when it gets below the "I can't start my car"-level without some sort of smarts either in software or extra hardware. Also part of that is having the OS be aware that it's running on the charger so it doesn't go to sleep. IDK if android is smart enough to do that.
    Yeah but even if the cig lighter doesn't power off with the car that's a pretty simple problem to fix with a single relay. I hear your point about runing down the car battery if the tablet continues to charge, but as mentioned a simple relay will take that problem away. The tablet battery should be able to keep it sleeping until the next drive.
  2. #12
    Mod - iPad Forums RipplingHurst's Avatar
    Dec 2007
    Danville, CA
    My cig lighter does not turn off immediately either, but it turns off eventually to protect the battery. I'd say it stays on for at least 30min, maybe much more but not less. The iPad, the computer, even a fridge can stay on for quite a while, but the car electronics takes care of it.
  3. #13
    Nov 2004
    St Louis
    Quote Originally Posted by Bugbyte View Post
    One of the things I actually like about my iPad install is that it doesn't depend on the car power system, although the car will charge it when it is turned on. If you stop and restart the car, the iPad doesn't miss a beat. I'm sure an Android tablet - or any tablet, for that matter, would work the same.
    Another convert!
    Granted, my install uses a removable iPad. That makes boot time irrelevant. It's already on when I put it into the holder, I just have to swipe the unlock button. That's not as cool as auto wake up or auto start but it doesn't bother me as much as it might bother someone else.
    Hopefully, it will also autoconnect with your USB devices, too. Took me a long time to get USB to sync and even now it takes as long as booting from standby.
    Auto-sleep or shutdown is the only thing I would like to have. I still manually click the sleep button when I shut the car off or else the screen stays on. A for-car FE app should be able to detect a power state change and sleep the device and I'm sure the same could be done for any type of tablet -but that requires FE software. Which doesn't exist yet.
    I'm sure someone will come up with something similar to Powermon for you guys one day. There are also a couple programs out there for the PC laptop that don't require Front-end support, not to mention its part of the OS in windows for most laptops/tablet/etc.
    Those two issues are minor inconveniences but they do expose the IPad as not perfectly integrated with the car.
    FIXED!
    DUH! Sorry couldn't help myself.
  4. #14
    May 2003
    Crystal Lake, IL
    there are going to be lots of android tablets out there to play with!
    7" touchscreen with lots of built in stuff for under $200!
  5. #15
    Newbie c3mediacar's Avatar
    Aug 2005
    This week i update my tatoo with a 2.2 Rom and i see the Car Home app on it, mybe its a good starting for a android fe.
    You can see more at http://googlemobile.blogspot.com/201...-personal.html
  6. #16
    Dec 2006
    Quote Originally Posted by c3mediacar View Post
    Thanks for the link... I found this interesting. Since the Archos 5 is internet ready and has GPS, it could be used as a Car PC killer as well. Android 2.2 has been released for it and with a few tweaks you can get the Android Market and use this Car Home app as well.
    I still haven't found a free navigation software better than Google Maps with Navigation, only it uses your phone's 3G/EDGE connection to get info on places, but you can also pair it with your Android smartphone to get the internet.
  7. #17
    Dec 2007
    Danville, CA
    I love that. I wonder if they're going to make it a tablet version of this for the Galaxy tab...
    Very cool automatic launch with BT pairing! Never thought of that. Also when docking. Very clever.
  8. #18
    Dec 2006
    Quote Originally Posted by RipplingHurst View Post
    Likely, its in the market so if you get the Galaxy Tab and install Car Home you should be good to go.
    How you going to attach it to your audio system tho?
  9. #19
    Dec 2010
    I have successfully installed the galaxy tab into a double din of a 06 mustang all speakers are working and it is a permanent install if u would like to know how just ask
  10. #20
    Dec 2010
    Btw for audio just buy an external amp wire the car speakers to the output side... take the headphone jack and plug in a rca to headphones jack cable and take that cable to the input side of the amp... wire in an equalizer in series to act as ur volume control... i did this to the 06 mustang I spoke of earlier and everything works like a charm
  1. $100.00, ebay or used, Android tablet as headrest screen?
    By RipplingHurst in forum Android Tablet
    Last Post: 05-19-2011, 02:26 AM
  2. 10" Viewsonic Android 2.2 multitouch wifi tablet
    Last Post: 11-05-2010, 07:27 PM
  3. Vehicle purpose android tablet: Vivid
    By qbunnie in forum Android Tablet
    Last Post: 11-04-2010, 02:50 AM
  4. MP3Car CarPC State of the Union 2006
    By SwapMeet in forum General MP3Car Discussion
    Last Post: 10-18-2006, 09:32 PM
  5. Replies: 33
    Last Post: 09-01-2005, 05:14 PM
