Results 1 to 10 of 15
Thread: Possible to adapt laptop to 3.5mm ?
    Oct 2011
    Cheyenne, WY
    My car has a 3.5mm video input on it. It also has usb hookup, but I havent been able to get that to do anything with a usb/usb cable.
    Is there a way to convert usb to 3.5mm video? I'd like to make a cable myself, but I cant find a schematic to make one. Anyone have any tips?
    North of the land of Hey Huns
    Jun 2004
    Westminster, MD
    What vehicle (Year, Make, and Model), what navigation system, and what kind of inputs does it support (As according to your dealer)?
    "3.5mm video input" means nothing, and is not really of any help. What you need to find out, is what kind of video input does it support, and go from there.
    RevFE
    My Shop
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    He asked the same question over at the CF forum. Here's what I know so far:
    He has a 2012 Hyundai that has a head unit with USB (most likely for mp3/iPod/iPhone) and a 3.5mm a/v input.
    He has a Pavilion dv6 laptop.
    If you want to read the entire thread, here you go.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
    Oct 2011
    Cheyenne, WY
    Honestly dont know what kind of video input it supports. The system is running on Windows CE, with a shell program. Car is a Hyundai Veloster.
    I know it will play other things through the 3.5mm. Xbox works, but I know thats not the same as a computer.
    Raw Wave
    Nov 2009
    Excellent info.
    Maybe the capacitor (1F) could help buffer the signal? Probably more useful than its current - I mean, voltage application.
    Trey - I think your are trying to match incompatible systems - a bit like converting a monitor headphone output to carry video (though that's often easy) - or rather, converting it to a video input....
    And if it involves video signal conversion (RGB to composite or HDMI or CYM etc), then IMO forget it - it's cheaper else better changing equipment - though some adapters are an economic option.
    Jul 2010
    Am I the only one that never understands anything that OldSpark says?
    Probably very knowledgeable but for someone like me, i need a translator lol..
    Oct 2011
    Cheyenne, WY
    Sounds good, I'll look for another solution.
    I thought I had seen where someone tied in to the stock display for their carpc. maybe I was wrong.
    Nov 2010
    Panama City Beach
    The head unit has a 3.5mm video and audio input, much like the cables included with video cameras and portable dvd players. It is very easy to convert analog video to composite, and then connect that to a cable that has composite and two channel rca cables that terminates into a 3.5mm plug (which is included with that particular head unit, apparently). The video quality will most likely suck, but it is possible to achieve what the OP wants.
    Raw Wave
    Nov 2009
    Thank-You kegobeer!!
    Quote Originally Posted by Sledge1 View Post
    No - I think you are in fine company, and by far the majority!
    The capacitor bit was me being ridiculous - much as caps for audio systems are ridiculous, and (IMO) extremely amusing (with some exceptions - I'm talking about "the norm").
    I thought the rest was ok though - I just thought of whatever video TLAs etc I could think of (TLAs being Three Letter Acronyms - a subset of MLAs or Multi Letter Acronyms), and my vague recollection of the lack of cheap video converters else their compromised quality. (Though converters now have the possibility of being quality and cheap.)
    BTW - if ever I confustigate you, please ask for clarification if you are interested.
    If it's my jargon or Aussie slang etc, that is usually easy to fix.
    But as to technical complexity, I only too well understand! Especially the simple misunderstandings that underpin much stuff (like caps for amps; battery & charging system behavior; etc) - often so simple in hindsight , but tricky as all hell until YOU get to see the big picture. (And as I suggest, hence easy to get things so wrong or expensive due to some simple misunderstanding or miss - not that I do that, well... not since Thursday anyhow.)
    FYI "confustigate" comes from an old "good-boy's" curse: "Confustigate the muddy bucket of pitch". (To me it sounds like "confuse", though I only know what the last words translate to!) Alas I liked that curse - you can't be told off for foul language. (Much the same as when people tell me "You can't!!" and I reply "DON'T call me a can't!!". That should work in American English too.)
    Apologies for another longie, but I hope the extra stuff was worthwhile.
    May 2010
    Australia
    Would now be a good time to point out that Sledge is an Aussie
    I too was wondering where on earth you were pulling the capacitor from..
    I don't think it is impossible but yes it sounds like an analogue signal as mentioned used by many cameras. The tricky part will be figuring out what sort of analogue signal and getting the computer to output the same thing.
  1. KRAZO'S laptop home made laptop stand
    By KRAZO_EG6 in forum Show off your project
    Last Post: 05-12-2008, 02:54 PM
  2. FS FT Laptop Memory, Internal Laptop Wifi Card, HD, Bluetooth
    By FiReBReTHa in forum Classified Archive
    Last Post: 04-17-2006, 07:24 PM
  3. Replies: 6
    Last Post: 02-22-2006, 08:19 PM
  4. Replies: 7
    Last Post: 07-12-2005, 03:02 PM
  5. can you adapt a serial device to USB? (ODB-II)
    By mattress in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 02-12-2005, 04:17 PM
