Here's two dumb ideas, but I'm doing one of them in my car..
idea 1) If you can buy a docking station (I have Dell, so it's easy) it has a second
power swith on it. Tap into that, run a momentary swith to the front with low voltage and insto-presto...1 power tap!
idea 2) No Docking Station available? Open the
laptop, find the bower button solder points and make a second external switch (and or connection adapter) and add to your car a relay and momentary switch to apply physical pressure to your switch to simulate your finger pressing it. You can position the Relay directly in line with your external switch (or over your docking Station power switch). Now you have power juicing up the Relay and switch, press the button, and off goes your magic finger!!
I got the idea when I saw somebody "Buzz" a person through a door. It all clicked, Button-->Relay-->Manual mechanism to extend/retract.
I know it's crude, but hopefully it's an idea you don't have yet!
(i'm dong idea 2, less chance of frying my mother board, and easy to run the wires)
