Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Surface Pro 3
    Apr 2011
    Janesville, Wisconisn
    Surface Pro 3
    Looking at putting a Surface Pro 3 in dash flush mount.
    Anyone done this looking for mounting ideas?
    Pros and Cons about using a Surface Pro 3
    Any links to previous threads would be great too.
    My idea is to make it removable use it in the house take it out to the car and use it there.
    Apr 2011
    Also this is in a 1951 Ford Custom Build so space and modification to the dash is not an issue.
    FLAC SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Pictures of dash area would help. SNO
    Apr 2011
Size:  157.2 KBName:  interior2.jpg
    Nov 2009
    Keswick,On Canada
    Wow no wonder your confused and looking for suggestions. What a nice big area to work with, almost too big And a beautiful looking truck from what I can see Good luck SNO
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Quote Originally Posted by bones5133 View Post
    Currently doing a Surface pro 2 - here: http://www.mp3car.com/laptops-netboo...pro-2-a-5.html
    Main problem for most seems to be turning it on/off - I find it very risky in a vehicle to have anything but the power button as the power control device, I'll be getting to my solution in the next few weeks.
    Other problem is no stereo audio input. However audio line (headphone) out it very good quality with no noise. Other wise a USB sound card or DAC. See my thoughts on the dam DAC I tried.
    Other things are with one USB port there is a limit to the number of USB devices and HUBS (15 total) before you run out of USB resources.
    And finding a way to control backlight for night driving without having to do it manually - may have an answer on that soon.
    Dam nice truck.
    Surface Pro 2 128GB portrait mode, Win8.1, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE. Previous Car-PC Project
    Apr 2011
    Mickz thanks for the input. I will be following your thread closely. I do have time on this build as I lost my car in a fire and am in the process of rebuilding the same car. Is there a reason to not go with a SP3? Besides expense.
    Are you working on a solution for power on when vehicle starts?
    What about charging?
    I am looking to have the same mount as above. Nice and flush but removable. Any pics of your build?
    ThanksName:  streetrodpicltside4.jpg
    Variable Bitrate camo.b's Avatar
    Nov 2011
    Yes nice car!! What screen size were you running in those photos? Like SNO said...what a fantastic area to work with almost limitless..i for some reason am craving a vertical mounted screen but ive done a horizontal mount.
    Sep 2009
    Australia
    I already had a SP2, so for now I'm using it - Nice thing about completely redoing my original install - I'm making this new setup completely independent of the Tablet/PC or whatever else comes along. Just needs a USB connection and running an OS that I programmed my FE for/in.
    The only thing needed for vehicle starting is the external 5v USB hub power - (I have 12 USB devices - not including HUBS) - You'll see in that thread my simple solution for this and how it's automatically controlled by any tablet or PC that the USB cable is plugged into.
    No start-up or shutdown controllers needed - Tablet has it's own power so no external or AUX batteries needed - simple clean install.
    I'll be posting pictures of the install soon, I'm still testing every scenario and vehicle condition on the bench - and I mean exhaustive testing - learnt from 5 years of living with a very complex but eventually 99% reliable Car-PC installation.
    As far as charging, there is a 12v vehicle charger available. but all I really need is the magnetic plug. I believe that the keyboard with the second battery bank built in, supplies power to the SP2/3 through the keyboard connection? - I'll be looking at that as well when I get the external build finished.
    I'm doing this mount a little differently - the SPro will sit on/into a larger recessed aluminium backing plate (heat transfer as well) with plenty of room around it - makes connections simple. The SP will be held in place by a strong (hidden locking) clip in fascia insert, so Tablet removal is quick and simple, any time I change the Tablet - like going to an SP3 when prices drop - I only need to change the fascia insert.
    Nov 2011
    Mickz are you running the surface with windows 8 still or have you wiped it and loaded somthing else?
  1. MS Surface Pro 2
    By Mickz in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: Yesterday, 09:09 PM
  2. may try w surface pro?
    By buckemdwn in forum Road Runner
    Last Post: 02-21-2013, 06:03 PM
  3. Microsoft Surface Tablets
    By bblitz in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 09-05-2012, 09:19 AM
  4. Surface Acoustic Wave SAW
    By ssteger in forum VaultWiki
    Last Post: 10-19-2009, 02:39 PM
  5. All about Microsoft Surface
    By add1 in forum General Hardware Discussion
    Last Post: 10-11-2007, 09:34 AM
