Results 1 to 7 of 7
Thread: Noise on audio from laptop
    pip
    pip is offline
    Maximum Bitrate pip's Avatar
    Mar 2004
    Parker, CO
    Question Noise on audio from laptop
    I hope some of you people with more experience than me can help with this one:
    My plan is to connect my old laptop (Gateway Solo 9300) to my Corvette audio system to use it as a carputer. I have a dongle that connects to the CD-Changer cable in the corvette to provide an aux-in. This works really well and the sound is really clean, I've been using it with my Archos MP3 player for some time.
    I installed GPS s/w and Audio Engine and connected the headphone socket of the gateway to the aux-in and it played really clean audio. However, I connected the car/plane 12v to 19v power adapter (bought from gateway at the same time as the pc) and I immediately started getting noise in the audio. This noise is not a ground loop but is noise generated by hard disk accesses and mouse movements on the PC.
    Is this the power adapter? Would getting another one make any difference?
    Would a USB sound card fix the noise? Should I say 'stuff it' and build a dedicated carputer and forget the laptop? Though, apart from the noise the laptop is working just fine.
    Help?
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Any ideas?
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    Quote Originally Posted by pip
    I always thought that was a ground loop. Your laptop power adapter is causing the problem--it needs to be grounded properly. I understand that you probably dont want to cut it up, but you gotta do something to ground it better. The ground for the Cigarette lighter is horrid.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Dec 2003
    ATL GA
    When I tried a laptop configuration before, I found that the only way to clean those noises out was to ground the laptop battery to the car chassis. Not desirable unless you don't mind making mods to your laptop. You can try using chassis ground for you audio input signal ground to the amplifier. Most people might say NO! don't do that, but they don't realize that 99.9% of the car stereos and amplifiers out there use basically chasis ground as the gorund for the audio signal, hence ground loops and engine noise. You have to spend alot of money to get a true balanced line output from a high end headunit.
    pip
    pip is offline
    Mar 2004
    Parker, CO
    Thank you both, I'll try to improve the ground & see what happens.
    I still may go the route if a mini-itx pc, especially now I see that PentiumM ITX boards are being made
    Gip
    Gip is offline
    Jan 2005
    Nov 2006
    Gloucestershire, UK
    If your using an inverter, that's you problem. It's causing interferance. Move it away from the laptop.
  1. LCD making noise when connected to laptop.
    By jabba in forum LCD/Display
    Last Post: 07-19-2007, 07:10 AM
  2. noise in audio
    By Harvester in forum General Hardware Discussion
    Last Post: 10-03-2005, 08:40 PM
  3. Hard audio quality problem: Noise / Ground loop?
    By Burat in forum General Hardware Discussion
    Last Post: 09-09-2004, 07:08 AM
  4. Replies: 11
    Last Post: 12-02-2003, 08:29 AM
  5. How to eliminate noise in audio
    By felix99 in forum General Hardware Discussion
    Last Post: 09-20-2002, 12:31 PM
